Possibility of a RWD conversion in a 96 Civic
Old Dec 22, 2006 | 04:36 PM
4NOWJUSTADX's Avatar
Default Possibility of a RWD conversion in a 96 Civic
I know it would be expensive and require alot of fabrication, but would it be possible to put an S2000 engine, tranny, and rear end?
Old Dec 22, 2006 | 04:42 PM
Padawan's Avatar
Darth ModerVader
Default Re: Possibility of a RWD conversion in a 96 Civic (4NOWJUSTADX)
With this,
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 4NOWJUSTADX &raquo;</TD></TR><TR><TD CLASS="quote">expensive and require alot of fabrication</TD></TR></TABLE>
just about anything is possible.
Old Dec 22, 2006 | 04:43 PM
dohcVTECeg2's Avatar
Default Re: Possibility of a RWD conversion in a 96 Civic (Padawan)
anything is possible with an abbundance of money
Old Dec 22, 2006 | 04:54 PM
bmoua's Avatar
yep haven't you guys seen the awd teg haha...
Default Re: Possibility of a RWD conversion in a 96 Civic (dohcVTECeg2)
has anyone done it? Would the driveshaft interfere with the bottom of the chasis?
Old Dec 22, 2006 | 05:01 PM
Miracle's Avatar
This guy put a 383 in a Prelude... so anything is possible...
https://honda-tech.com/zerothread?id=1645997
Old Dec 22, 2006 | 05:17 PM
Padawan's Avatar
Darth ModerVader
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 4NOWJUSTADX &raquo;</TD></TR><TR><TD CLASS="quote">has anyone done it? Would the driveshaft interfere with the bottom of the chasis?</TD></TR></TABLE>
Of course it would, but you yourself stated:
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 4NOWJUSTADX &raquo;</TD></TR><TR><TD CLASS="quote">I know it would be expensive and require alot of fabrication</TD></TR></TABLE>
Old Dec 22, 2006 | 05:19 PM
highroller54's Avatar
if you click my sig it is a 4wd hatch, has a rear drive shaft, might give you some ideas.
Old Dec 22, 2006 | 05:21 PM
Miracle's Avatar
Default Re: Possibility of a RWD conversion in a 96 Civic (highroller54)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by highroller54 &raquo;</TD></TR><TR><TD CLASS="quote">if you click my sig it is a 4wd hatch, has a rear drive shaft, might give you some ideas.</TD></TR></TABLE>
Linky no worky.
Old Dec 22, 2006 | 05:46 PM
doood's Avatar
been there done that
you answered your own question with this..
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 4NOWJUSTADX &raquo;</TD></TR><TR><TD CLASS="quote">I know it would be expensive and require alot of fabrication, </TD></TR></TABLE>
why ask more questions?
Old Dec 22, 2006 | 05:54 PM
Default Re: Possibility of a RWD conversion in a 96 Civic (doood)
because some things are worth time, money, and effort
Old Dec 22, 2006 | 05:56 PM
doood's Avatar
like an s2000 rwd conversion? that's worth more bling points than anything else.
Miracle's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 4NOWJUSTADX &raquo;</TD></TR><TR><TD CLASS="quote">because some things are worth time, money, and effort</TD></TR></TABLE>
Does this REALLY fall into that category though... HONESTLY?
Old Dec 22, 2006 | 06:53 PM
Default Re: Possibility of a RWD conversion in a 96 Civic (Miracle)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Miracle &raquo;</TD></TR><TR><TD CLASS="quote">
Linky no worky.</TD></TR></TABLE>
it works HMT was down
Old Dec 22, 2006 | 07:14 PM
Miracle's Avatar
it works HMT was down </TD></TR></TABLE>
DDDAAAMMMNNN dude.... that build is SICK.
Too much time and money in an old car for MY taste, but mad props for the time and effort...
Old Dec 22, 2006 | 08:24 PM
Wonk Unit's Avatar
soo would it be possible to mount a regular honda engine the other way, find a drive shaft, and rear end?? it my friends and i get a shell of a del sol, we might try it...
Old Dec 22, 2006 | 08:32 PM
Too much time and money in an old car for MY taste</TD></TR></TABLE>
this ones built on the cheap, my eg on the other hand......................
Old Dec 22, 2006 | 08:35 PM
Kamin's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 4NOWJUSTADX &raquo;</TD></TR><TR><TD CLASS="quote">I know it would be expensive and require alot of fabrication, but would it be possible to put an S2000 engine, tranny, and rear end? </TD></TR></TABLE>
if you have to ask this question, you dont know enough about fabrication or engines/drivetrains in general to attempt this project.
LudeCris
Apr 9, 2006 05:09 AM
btrim23
Feb 7, 2005 08:09 PM
lv6l
Nov 24, 2004 10:31 AM
jdm236
Sep 29, 2004 05:37 PM
