92 b17a1 gsr rebuild
Old Dec 22, 2006 | 02:33 PM
2ndgent3g's Avatar
Default 92 b17a1 gsr rebuild
ok well im getting a 92 gsr with 100,000 miles on it and well im thinking about rebuilding it. iv searched and found a couple threads on rebuilding the b17. im planning on keeping it since the motor is rare to find and there were only i think 3500 made???? now back to the rebuild i found a site that has a rebuild kit with
Complete Gasket Set
Cometic Head Gasket
Wiseco Pistons (your choice)
(#K542M81, .81mm, 9.2-1)
(#K542M815, 81.5mm, 9.2-1)
(#K566M81, 81.5mm, 11-1)
(#K566M815, 81.5mm, 11-1)
(#K566M82, 82mm, 9.2-1)
(81, 81.5, 82mm, 10.0-1, 10.5-1
Performance Rings
Performance Wrist Pins
TOGA HP Main Bearings
TOGA HP Rod Bearings
Thrust Washers
Timing Belt
Expansion Plugs
for $989 is that a good deal? and a good rebuild kit?
im trying to get around 175-200 hp out of it at least.
do you guys have any suggestions on what i should do? i know the basics. i just want some suggestions to go buy. i had a 92 ls so i im new with the vtec part. so guys put in your suggestions to help me out thnx.
Old Dec 22, 2006 | 02:52 PM
cafcwest's Avatar
Default Re: 92 b17a1 gsr rebuild (2ndgent3g)
at 100k I seriously doubt your going to need to replace the pistons.
Make a friend at your local stealership, get replacement color coded OE bearings, OE rings and gaskets.
Honda knew what they were doing - just try not to pay out the nose for it
Old Dec 22, 2006 | 05:51 PM
vladd's Avatar
with only 100k, chances are that the motor's still in great shape. unless there's something noticeably wrong with it, don't bother rebuilding it. replace the timing belt, water pump, and maybe plugs and wires.
Old Dec 22, 2006 | 06:03 PM
Blk-dc2's Avatar
Default Re: 92 b17a1 gsr rebuild (civicdxtyper)
yeah, my 95 gsr has 140XXX and i'm not even thinking of a rebuild until maybe 200XXX....thats if i don't do k-series or type-r...
Old Dec 22, 2006 | 06:33 PM
Sam92Teg's Avatar
Do a compression test to see the condition of your engine. If you get good numbers relatively close to each other, then save your money and do regular maintenance. Then start your research on performance parts.
The kit you posted includes forged pistons, which you really don't need. Even if you decide you want to rebuild, research and buy your parts seperately for quality and price advantage.
Over 300K miles here without a rebuild, and doing well, still get 32 mpg.
Old Dec 22, 2006 | 09:30 PM
2ndgent3g's Avatar
ok well i guess then i should do a regular maitnance on the car? like compression test, change plugs, gaskets and bearings? he said no smoking or problems with engine so i gues thats a good thing. then just get some bolt ons maybe? ...thnx on the replies iv gotten. any more suggestions out there?
Old Dec 23, 2006 | 12:23 AM
2ndgent3g's Avatar
the 3rd gear is kinda gone after 4500 rpms it grinds so i need to get that fixed and put lsd in it. any one know where i can find lsd for this tranny i believe the ys1? ..
Old Dec 23, 2006 | 12:45 AM
92integraVTECgsr's Avatar
Default Re: (2ndgent3g)
buy a quaife LSD. Fix the grinding gear(s). Do a compression test. Do a timing belt, water pump, tensioner. Dist. Cap, rotor, plug wires, plugs.
Bolt on parts: AEM Cold Air Intake, Headers of your choice, exhaust. Lower it with ground control coilovers and tokico illumina 5-way adjustable shocks or koni yellows if you want. PBR Ultimate pads, bleed the brakes good and go drive and have a **** load of fun with your new car.
Old Dec 23, 2006 | 10:35 AM
2ndgent3g's Avatar
Default Re: (92integraVTECgsr)
yea thats sounding great! hey i have a obd-1 vtec distibutor in box new, itr oil pump and water pump and itr timing belt all new still in box. will itr stuff work? ill just use all that to replace everything if so. and for the aftermarket parts for bolt ons sounds good, kinda what i had in mind.
Old Dec 23, 2006 | 11:25 AM
full Circling's Avatar
From: That's the wrong tone... I'm Skunk2 certified.
I gonna be blunt. That rebuild kit you mentioned contains McShit. Toga? Sounds like a Toda ripoff to me. Only use OE Honda bearings. The head gasket and pistons are good, though.
Old Dec 23, 2006 | 01:05 PM
2ndgent3g's Avatar
yea i was thinking the same thing toga sounds like a ripoff toda or somthing? but im planning on using oem honda parts. thnx
Old Dec 23, 2006 | 01:24 PM
2ndgent3g's Avatar
i know the itr oil pump will go on but will the itr water pump and timing belt also? anyone know...
Old Dec 23, 2006 | 02:34 PM
doood's Avatar
been there done that
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 2ndgent3g &raquo;</TD></TR><TR><TD CLASS="quote">i know the itr oil pump will go on but will the itr water pump and timing belt also? anyone know...</TD></TR></TABLE>
the pump will fit. the belt wont. you need a b16 belt.
Old Dec 23, 2006 | 08:09 PM
2ndgent3g's Avatar
a b16 belt? i thought i heard you cant do that because the teeth or somthing?
Old Dec 23, 2006 | 09:30 PM
b16, b17, B18c5 timing belts are all the same as far as a I know. I'm using a B17 belt on my B16 and its works great.
As for the ITR Oil pump I dont think it will work because it's OBD2 and ur car is OBD1.
Old Dec 24, 2006 | 11:40 AM
2ndgent3g's Avatar
no im sure the itr oil pump will work cause i was goin to do lsvtec and it is obd-1 but that has nothing to do with the oil pump i believe the itr oil pump fits any b-series?? but i know the belts i thought you have to have the same pump for it? maybe im incorrect.
Old Dec 24, 2006 | 12:44 PM
doood's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 2ndgent3g &raquo;</TD></TR><TR><TD CLASS="quote">a b16 belt? i thought i heard you cant do that because the teeth or somthing?</TD></TR></TABLE>
all b series vtec pumps have 22 teeth. you need a b16 belt because it's the correct length. b18c belts would be too long.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 92integraVTECgsr &raquo;</TD></TR><TR><TD CLASS="quote">b16, b17, B18c5 timing belts are all the same as far as a I know. I'm using a B17 belt on my B16 and its works great.
As for the ITR Oil pump I dont think it will work because it's OBD2 and ur car is OBD1.</TD></TR></TABLE>
b16/17 belts are shorter than b18c belts.
Old Dec 24, 2006 | 07:28 PM
2ndgent3g's Avatar
ok well thanx for clearing that up...i ment lenth like to many teeth because its to long..lol...somthing like that.
Old Dec 26, 2006 | 02:38 PM
2ndgent3g's Avatar
hey if the tranny grinds in 3rd all i have to do is take it to a transmision place and have them fix it right? or a special kind of place?
Old Dec 26, 2006 | 02:40 PM
doood's Avatar
try some gm syncromesh first and see if that helps the problem. if not you're likely looking at a rebuild which is costly.
Old Dec 27, 2006 | 09:51 AM
Death_to_Thieves's Avatar
when I bought my 92 GSR it had 121,xxx on it. 3rd gear had a slight grind in high rpms. Put in Pennzoil synchromesh and it never grinded ever again. I mean it NEVER grinded again. That stuff is amazing.
Old Dec 27, 2006 | 01:16 PM
2ndgent3g's Avatar
yea so which is better pennzoil or gm? i herd gm synchromesh is best i read a little on it but i guess everyone has there opinions??
john_lauj
Jan 29, 2009 09:07 AM
PROJECT 91
Dec 10, 2008 12:42 PM
pocket
Mar 28, 2008 08:32 AM
shwanky
Mar 9, 2005 10:52 AM
