anyone know anything about distributors?
Old Dec 22, 2006 | 02:28 PM
crXXXalex858's Avatar
Default anyone know anything about distributors?
here's the proplem, when i start my car up in the morning or whenever it's cold it drives perfect. after warming up to the regular temp it starts to bog a lil bit only when im accelerating. it also has a slow acceleration! on the freeway its smooth but stop and go sucks! i changed the ecu already,can it be the distributor?
Old Dec 24, 2006 | 01:50 PM
Mavrick's Avatar
Default Re: anyone know anything about distributors? (crXXXalex858)
it is something with the ignition system. Distributor would be a good place to look, is your car throwing any codes?
Old Dec 24, 2006 | 04:01 PM
Fezzie's Avatar
Default Re: anyone know anything about distributors? (Mavrick)
try changing the ignitor in the distributor, its a little box with three prongs on the bottom and one on the side.
Old Dec 24, 2006 | 04:08 PM
Crx Jimmy's Avatar
Default Re: anyone know anything about distributors? (Fezzie)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Fezzie &raquo;</TD></TR><TR><TD CLASS="quote">try changing the ignitor in the distributor, its a little box with three prongs on the bottom and one on the side.</TD></TR></TABLE>
bingo, I had the same problem. car would throw a code or sometimes shut off. when I tested the ignitor, it was cold it would test to specs. couldnt figure it out but swapped it, and the problem went away must be when it got hot it caused problems. worth a shot, I had a spare dizzy to get parts from, I would borrow one before buying one though.
Old Dec 28, 2006 | 12:05 PM
Default Re: anyone know anything about distributors? (Crx Jimmy)
no codes are flashing, i thought the ecu was bad,but i changed it and its still the same.
Old Dec 28, 2006 | 12:07 PM
yea i cant find anyone with a obd0 sohc si, everyone has swaps now a days. i'll just order a new mod thing for the dizzy.
Old Dec 28, 2006 | 12:14 PM
DaX's Avatar
DaX
Loved
Community Favorite
If it is your ICM, you could always get a bling bling MSD unit and go ignitorless.
jrxiongs
Aug 26, 2008 03:06 PM
LilCivic04
12
Oct 13, 2005 01:29 AM
IntegD
Apr 2, 2004 10:16 AM
BLUE EH3
21
Jan 10, 2004 11:22 PM
GQ Cowboy
May 17, 2003 07:10 PM
