Need help with JDM Integra Type R cluster into my Integra Ls
Old Dec 22, 2006 | 02:00 PM
HNP's Avatar
HNP
Default Need help with JDM Integra Type R cluster into my Integra Ls
whats goin on guys, i have a 1998 LS and i just bought a type r cluster but the gas needle and temp doesnt seem to work. my car is obd2 and the type r cluster is obd1 is from the 96 spec. anybody know how to wire it right? thanx for the help guys!
Old Dec 22, 2006 | 02:30 PM
KDP's Avatar
KDP
Default Re: Need help with JDM Integra Type R cluster into my Integra Ls (HNP)
what I did when I swapped mine out was take the gauges out of the ITR cluster and put them in my LS cluster. Then I swapped the carbon fiber trim to my LS shell with ITR gauges. You have to keep the LS inserts though in the trim piece. Worked like a champ.
Old Dec 22, 2006 | 02:58 PM
CARMA_626's Avatar
I drive a G35, it's silver, surprised?
Default Re: Need help with JDM Integra Type R cluster into my Integra Ls (KDP)
This is the easiest way to do it:
All you have to to make a OBD1 cluster work in a OBD2 car (or visa vera) is remove the green film on the back of the cluster and swap it with cluster you want to use. Takes about 10 mins.
The green film is held on by about 13 phillip head screws. Just take those off, switch it out, and you're good from there.
Like this: (by the way, I searched and quickly found these pics)
Old Dec 22, 2006 | 03:09 PM
BlueIntegraBoy's Avatar
I know I made this for a reason...
https://honda-tech.com/zerothread?id=1836281
Old Dec 22, 2006 | 03:36 PM
HNP's Avatar
HNP
thank you guys, i will be trying this...
tjlewis10
Sep 11, 2017 08:16 AM
worx
Aug 17, 2009 03:02 PM
mike integra
Sep 17, 2008 06:29 PM
gldndrgn14
Apr 30, 2005 07:48 PM
Pretegra
Aug 13, 2004 01:26 AM
