More axles questions
Old Dec 22, 2006 | 12:10 PM
powerpro_69's Avatar
Default More axles questions
so i have a JDM crx set up and need to replace the axles what do i need to do or where can i get them at
Old Dec 22, 2006 | 12:20 PM
civicjdmb16a's Avatar
Default Re: More axles questions (powerpro_69)
depends which half shaft you have and what trannyyou have.
Y1= 90-91 integra axles
anything else and i like to use 89 integra axles
you can get them at any autoparts store
Old Dec 22, 2006 | 12:24 PM
RockinthEFhatch's Avatar
Default Re: More axles questions (civicjdmb16a)
90-93 Integra GSR w/o ABS
Old Dec 22, 2006 | 12:38 PM
abnaasefmb's Avatar
Default Re: More axles questions (RockinthEFhatch)
use jdm ones, have them overnighted from Japan.
Old Dec 22, 2006 | 12:42 PM
Zaakro's Avatar
Default Re: More axles questions (abnaasefmb)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by abnaasefmb &raquo;</TD></TR><TR><TD CLASS="quote">use jdm ones, have them overnighted from Japan. </TD></TR></TABLE>
My Japanese teacher is going back to Japan in Jan. So i might just do that.
Old Dec 23, 2006 | 12:17 PM
Default Re: More axles questions (Zaakro)
i have a JDM front end the spindles are diff from stock one the are like an 94+ teg
and i want ones that are like stage 2 or 3
Old Dec 23, 2006 | 03:52 PM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by powerpro_69 &raquo;</TD></TR><TR><TD CLASS="quote">i have a JDM front end the spindles are diff from stock one the are like an 94+ teg
and i want ones that are like stage 2 or 3</TD></TR></TABLE>
All the spindles are the same. I've used everything from 89-91 integra axles on my cable tranny and now i use gsr axles on my hydro. So I know that the spindles are the same. It all depends on your halfshaft. To use 94 and up axles you need to get a hydrualic halfshaft. If you are using a cable tranny and want to use hydro axles you also have to change the axle seals on the tranny. Getting high performance axles are very costly and should only be reserved for high HP cars.(i dont know what you have )I would go with driveshaftshop.com for axles if you are willing to get them.
vice
Mar 20, 2007 08:08 PM
xpman
Mar 1, 2006 01:49 AM
mr-mister
Sep 3, 2005 10:05 AM
b16crx0062004
Nov 17, 2004 06:13 PM
jdmDXrex
Feb 26, 2002 06:48 PM
