fan switch on ls/vtec
Old Dec 22, 2006 | 11:43 AM
russianswty's Avatar
Default fan switch on ls/vtec
Ok so im swapping a ls/vtec into my crx si. And
the fan switch exists on the back of that since its a obd0 block
but then the head has a fan switch as well which is right next
to the thermostat.
So so I use the one on the block or rether on the head for the obd1.
Oh and yeah I am running a obd1 ecu. But the obd0 sensor should work
fine as well right?
Old Dec 22, 2006 | 12:49 PM
e jay one's Avatar
Default Re: fan switch on ls/vtec (russianswty)
you can use either one your harness probably is wired for the one in the back by the oil filter though. the other one isnt on the head its on the thermo housing. either one will turn the fan on regarless of obd.
Old Dec 22, 2006 | 05:01 PM
Default Re: fan switch on ls/vtec (e jay one)
ok, and do you by any chance know what colors are the wires for that?
or does anybody have a better chart with which color goes to which plug?
Old Dec 22, 2006 | 07:25 PM
jakscivic's Avatar
when i did my lsvtec my fan switch seemed to not work after that. So i just made a manual switch inside my car.
1320king
Jul 27, 2009 12:05 AM
88 EF Hatch
May 31, 2009 03:42 PM
DEADLYACURACCY
Dec 26, 2006 11:14 AM
slamef
Feb 5, 2006 12:19 PM
riceball777
Apr 29, 2003 12:40 AM
