will a d16y8 valve cover fit
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Mr Hammond »</TD></TR><TR><TD CLASS="quote">D16Y5/7/8 all same valve cover.</TD></TR></TABLE>
If this is tru, then do the spark plug holes line up. I thought they were farther ahead on a d16y8. And with that being said, can you use the plug wires from a d16y8 on a d16y7, because i thought the spark plug holes were deeper?
Are you sure they are the same bc my d16y7 valve cover is different then my friends d16y8?
ALL 92-95 sohc vtec valve covers and ALL 96-00 sohc valve covers are interchangeable within each other, alot of people run 96+ valve covers cuz they are smoother than the pre 96's.
and ontop of that ALL 88-95 non vtec valvecovers are interchangeable within each other.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by schardbody »</TD></TR><TR><TD CLASS="quote">ALL 92-95 sohc vtec valve covers and ALL 96-00 sohc valve covers are interchangeable within each other, alot of people run 96+ valve covers cuz they are smoother than the pre 96's.
and ontop of that ALL 88-95 non vtec valvecovers are interchangeable within each other.</TD></TR></TABLE>
I'm runnin' a '92-'95 VTEC valve cover on my Y8 cuz it says VTEC on it...
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by EX-T »</TD></TR><TR><TD CLASS="quote">I'm runnin' a '92-'95 VTEC valve cover on my Y8 cuz it says VTEC on it...</TD></TR></TABLE>
ricer
ricer
ricer
hahha awesome.
ricer
</TD></TR></TABLE>hahha awesome.
ricer </TD></TR></TABLE>
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by boosted96coupe »</TD></TR><TR><TD CLASS="quote">
I am 100% positive. The part numbers are the same.
</TD></TR></TABLE>I am 100% positive. The part numbers are the same.
the head casting from a y8 and y5 are exactly the same they just have differnt vtec system if you go to Hondaautomotiveparts.com and check part numbers for the head casting same number, even though a y5 has j3 stamp from factory and y8 has j6 from factory. then if head cast same then valve cover same.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by EX-T »</TD></TR><TR><TD CLASS="quote">You guys ******' kill me!</TD></TR></TABLE>
i was kidding with you.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Jim Truett »</TD></TR><TR><TD CLASS="quote">Even the D17A1/A2 covers fit, and have a nice 5/8" breather port for crankcase evacuation.</TD></TR></TABLE>
good to know!!!
good to know!!!
