Can i use a 92 civic ex OBD1 Vtec Engine harness for my 1992 civic cx with a b16a2????
Old Dec 22, 2006 | 09:46 AM
92redhatch's Avatar
Default Can i use a 92 civic ex OBD1 Vtec Engine harness for my 1992 civic cx with a b16a2????
Can i use a 92 civic ex/si OBD1 Vtec Engine harness for my 1992 civic cx with a b16a2???? I have an obd1 distributer already.
thanks,
mike
Old Dec 22, 2006 | 10:10 AM
HondaPartsHero's Avatar
Technical Hero
Default Re: Can i use a 92 civic ex OBD1 Vtec Engine harness for my 1992 civic cx with a b16a2???? (92redhat
Yes, but you will still need to run the wiring for a knock sensor, everything else will be plug and play
Old Dec 22, 2006 | 10:14 AM
92redhatch's Avatar
im not using a knock sensor. I dont have a p30 ecu. i have a p28.
Old Dec 22, 2006 | 11:50 AM
Technical Hero
Default Re: (92redhatch)
you should be good to go then
Old Dec 22, 2006 | 11:51 AM
92redhatch's Avatar
thanks man.
Old Dec 22, 2006 | 11:53 AM
Technical Hero
Default Re: (HondaPartsHero)
oh wait just realized it was an A2. You're gonna have to swap the plug housings from your alternator onto the A2's to be able to use it (.http://img.photobucket.com/albums/v130/fobtions/alt.jpg). Also you're gonna want to get some injectors from at least an OBD1 DX/SI/EX for it to plug them in. Also you will have to run the intake air temperature sensor into the intake arm since the A2 won't have a place for it on its intake manifold.
Old Dec 22, 2006 | 11:56 AM
92redhatch's Avatar
are you sure the injectors wont plug in?
Old Dec 22, 2006 | 11:58 AM
92redhatch's Avatar
i called a few places locally here in miami and they all said it should plug up perfectly fine.
Old Dec 22, 2006 | 12:22 PM
Mr Hammond's Avatar
a/k/a Jomo
OBD2 injector harness' are different from OBD1.
Old Dec 22, 2006 | 12:24 PM
-HONDA-'s Avatar
integra Injectors OBD2 im using on a OBd1 harness they seemed too work!
theres injectors the have the staple looking thing and theres some that have just the slide in clip!
Old Dec 22, 2006 | 12:26 PM
Mr Hammond's Avatar
a/k/a Jomo
OBD2 and OBD1 injector plugs are different. I had to rewire mine using a '97 B18C1 into my '92 CX.
Old Dec 22, 2006 | 12:32 PM
92redhatch's Avatar
ya but i could just use the clips off the harness im using now ill just sauder ( spelling) them together if anything. But i was told they clip in.
Old Dec 22, 2006 | 12:48 PM
-HONDA-'s Avatar
OPh **** i forgot i cut the plugs off a obd2 harness and wired them too my obd1 LOL........sorry for the confusion!
Mr Hammond's Avatar
a/k/a Jomo
They won't. Yes you can rewire the clips to the harness. That's what I did.
DawgC2
Feb 1, 2013 12:57 AM
alsxe10
37
Sep 28, 2010 04:37 AM
92redhatch
Jan 5, 2007 11:53 AM
OTI-
Dec 20, 2006 04:30 PM
kr
Mar 23, 2006 06:31 AM
