upgrading front brakes calipers
im really interesting in getting my front brakes upgraded. i have already gotten better brake fuild, ss lines and pads....
im iinterested in ITR calipers or maybe just reg teg calipers with 11.1 rotors.. (akak fastbrakes is reg teg calipers)
are the ITR caliprs that much better? how can i make them work on my crx si
I know your suppose to use the EF EX front brakes for an upgrade but would it be possible to use 92 - 95 Civic EX front brakes as an upgrade? I see those a lot more than the EF EX brakes.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by CRX Toad »</TD></TR><TR><TD CLASS="quote">Contact Brian @ Fastbrakes and then search Big Brakes in the CRX/EF and search archive and current. </TD></TR></TABLE>
i been talking to brian thru email.
I at first wanted the Willwood kit from fastbrakes... but decided that would be over kill and wilwoods need rebulding much quicker then OEM caliper.(due to no dust seals)
so i got interested in the cheaper 11.1 rotor with teg caliper. I thought it would be a ITR calipers but turns out to be reg teg caliper. He told me today that the bracket will work with ITR calipers but i would need bigger rotors ("They can bolt on but they will not fit the rotors correctly they are too
tall." )
so now if i get bigger rotors.... would it work out? could i use his bracket and bigger rotors and make it work on an SI knuckle? would i need a bigger wheel then 15?
tall." )
Here is your one source of information if you want to use OEM Parts for your brake upgrade.
OEM Brake Upgrades For Any Use
JDM_rolex
Aug 6, 2007 11:44 PM
deucedeuceEK
Jan 12, 2006 01:13 PM
