upgrades for crx 91' si
im really interesting in getting my front brakes upgraded. i have already gotten better brake fuild, ss lines and pads....
im iinterested in ITR calipers or maybe just reg teg calipers with 11.1 rotors.. (akak fastbrakes is reg teg calipers)
are the ITR caliprs that much better? how can i make them work on my crx si
Then search for "CRX Brakes" in the archived Roadrace\Autox forum, smart guy. It turned up 9 results, several of which answer your question with detailed information.
What are you using this car for? If its daily driving or AutoX the biggest myth is that bigger brakes stop the car in a shorter distance. If this is for track use, I have had no major brake fade with my 88 CRX even in the middle of July at VIR on street tires. As long as you are on street tires you will be limited by the tires not the brakes. You have already changed the pads, lines, and fluid so your pedal feel should be very positive. If you still want to use ITR brakes, I would ask in the EF forum. I'm sure somepeople have done it just because its a HypeR setup.
1_slow_crx
Dec 22, 2006 07:45 PM
