b18c5 w/1" deck plate...should i buy?
Old Dec 22, 2006 | 08:12 AM
SpoolnByYou's Avatar
Default b18c5 w/1" deck plate...should i buy?
whats up guys,
i have the chance to buy a built type r block thats built.
BLOCK CONSIST OF:
TALL BLOCK IS SLEEVED AND BORED TO 86MM BY RS MACHINE AND HAS A 1 INCH DECKPLATE WELDED ON TOP
RODS CROWER STEEL H BEAM RODS WITH CROWER ROD BOLTS
ARAIS CUSTOM GAS PORT PISTONS WITH 6.3CC DOME
HASTING RINGS
95MM EAGLE CRANK
ACL BEARINGS
ARP HEAD BOLTS/STUDS
86MM COMETIC HEAD GASKET
all this for only 1800. i want this set up bad,and it looks promising,but i dont know what timing belt to run. ive tried searching and asking but nothing has come up. do you think this is a good deal and i should get it? and will the timing belt issue be a pain in the ***?
Old Dec 22, 2006 | 08:24 AM
lVlemphizStylez's Avatar
Default Re: b18c5 w/1" deck plate...should i buy? (SpoolnByYou)
the important fact is not thats it's built...But built by WHOM...thats EXTENSIVE work done, and if the ones who did it arent experiened in that type of work, youd be in trouble...Dropped sleeve city...Did RS machines do ALL the work, or just what you listed by thier name??
Old Dec 22, 2006 | 08:41 AM
Default Re: b18c5 w/1" deck plate...should i buy? (lVlemphizStylez)
RS machines built the motor
Old Dec 22, 2006 | 09:26 AM
i say go for it then
Old Dec 22, 2006 | 11:02 AM
doood's Avatar
been there done that
he plans to daily drive this thing. like said in your other thread, it will not make for a reliable daily driver.
Old Dec 22, 2006 | 11:07 AM
PrinceAli132's Avatar
Default Re: b18c5 w/1" deck plate...should i buy? (doood)
86x95 daily driver will not be reliable in my opinion.
Ali
Old Dec 22, 2006 | 11:11 AM
PatrickGSR94's Avatar
Community Builder
Community Influencer
Active Streak: 60 Days
1" deck plate, what does that do, increase the cylinder bore by 25mm?? umm wow, that's ALOT.
Old Dec 22, 2006 | 11:17 AM
gsrious's Avatar
Default Re: (PatrickGSR94)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by PatrickGSR94 &raquo;</TD></TR><TR><TD CLASS="quote">1" deck plate, what does that do, increase the cylinder bore by 25mm?? umm wow, that's ALOT.</TD></TR></TABLE>not bore. it increase your cyclinder height... hence the use of a 95mm crank.
Old Dec 22, 2006 | 05:37 PM
Community Builder
Default Re: (gsrious)
yeah my bad, I was thinking stroke but typed bore.
Still, a 1" longer stroke is a HUGE change. I don't know if that's a good idea to just slap an extra piece of metal there in between the head and block. Do you have to use 2 head gaskets with that??
Old Dec 22, 2006 | 05:40 PM
doood's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by PatrickGSR94 &raquo;</TD></TR><TR><TD CLASS="quote">yeah my bad, I was thinking stroke but typed bore.
Still, a 1" longer stroke is a HUGE change. I don't know if that's a good idea to just slap an extra piece of metal there in between the head and block. Do you have to use 2 head gaskets with that??</TD></TR></TABLE>
the deckplate is welded onto the deck of the block. so i guess you would only need one headgasket.
Old Dec 22, 2006 | 05:44 PM
kynetik's Avatar
why not contact RS if they built it? they should be able to give you the answer you're looking for.
Old Dec 22, 2006 | 08:24 PM
IHTFP's Avatar
youre trying to buy a race motor without knowing anything about it..
you need to learn what it is you are buying and then make an educated decision
94SiRswap
40
Feb 14, 2016 09:16 PM
em1effekt
Jul 7, 2012 12:22 AM
rrace002
Sep 8, 2011 04:36 AM
SpoolnByYou
16
Dec 23, 2006 05:11 AM
