Rota Slipstream - What's the right offset?
Old Dec 22, 2006 | 04:54 AM
Jesterian's Avatar
Default Rota Slipstream - What's the right offset?
I have rubbing in my front tires running Rota Slipstreams with 205/50/15 tires.
Just wondering if anyone can tell me what my offset is supposed to be to prevent this? The car is dropped about .75" on h&r sports, so the drop is not the issue.
Old Dec 22, 2006 | 07:21 AM
Furyof4's Avatar
Default Re: Rota Slipstream - What's the right offset? (Jesterian)
Where are you rubbing? I run +41 15x7 with 205 azenis(wider than most) and I only rub at full lock on the inside front frame rail. With +38 6.5" wide with same tires, I used to rub on the front and rear fender lips, I had to roll them both. +40 or more is what you want.
Old Dec 22, 2006 | 08:19 AM
oodie's Avatar
Im running 40 offset 15x6.5 with 195 50 15 with tein springs no rubbing at all.
Old Dec 22, 2006 | 08:24 AM
xDicktonesx's Avatar
Default Re: Rota Slipstream - What's the right offset? (oodie)
rota wheels are all +43. if youre rubbing its your car, not the wheel/tire.
what do you mean what is the "right" offset? are you going to "change" the offset somehow?
Old Dec 22, 2006 | 08:27 AM
STDClayton's Avatar
Default Re: Rota Slipstream - What's the right offset? (xDEFTONESx)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by xDEFTONESx &raquo;</TD></TR><TR><TD CLASS="quote">rota wheels are all +43. if youre rubbing its your car, not the wheel/tire. </TD></TR></TABLE>
no they're not.
Old Dec 22, 2006 | 08:29 AM
Default Re: Rota Slipstream - What's the right offset? (STDClayton)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by STDClayton &raquo;</TD></TR><TR><TD CLASS="quote">
no they're not.</TD></TR></TABLE>
enlighten
Old Dec 22, 2006 | 08:31 AM
ok they are +40.
still at 6.5 inches wide, nowhere near enough to rub with a 205mm tire.
Old Dec 22, 2006 | 08:35 AM
STDClayton's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by xDEFTONESx &raquo;</TD></TR><TR><TD CLASS="quote">ok they are +40.
still at 6.5 inches wide, nowhere near enough to rub with a 205mm tire.</TD></TR></TABLE>
especially with a 3/4" drop. i know that you (the OP) said that the drop isn't an issue...
oh, and you can get slips with a +38 offset, too.
Old Dec 22, 2006 | 04:33 PM
Jesterian's Avatar
I'm just trying to get some insight on why my tires may be rubbing. It happens when I take corners, even if I'm not taking it all that hard. I can't tell where it may be rubbing. I can hear it from the front though.
Old Dec 23, 2006 | 08:26 AM
ExemptedNut's Avatar
could be the inside of the tire rubbing on the inner fender well or spring perch maybe, maybe because of the body roll your getting when turning it causing the car to rib the tire.
Old Dec 23, 2006 | 08:52 PM
Jesterian's Avatar
Default Re: (ExemptedNut)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ExemptedNut &raquo;</TD></TR><TR><TD CLASS="quote">could be the inside of the tire rubbing on the inner fender well or spring perch maybe, maybe because of the body roll your getting when turning it causing the car to rib the tire.</TD></TR></TABLE>
So couldn't I just use a thicker spacer to move the tire out a whee bit?
Old Dec 24, 2006 | 09:06 AM
Zeppelin's Avatar
Default Re: (Jesterian)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Jesterian &raquo;</TD></TR><TR><TD CLASS="quote">So couldn't I just use a thicker spacer to move the tire out a whee bit?</TD></TR></TABLE>
Are you running a spacer right now? I hope not!
Old Dec 25, 2006 | 10:28 AM
Jesterian's Avatar
Default Re: (Zeppelin)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Zeppelin &raquo;</TD></TR><TR><TD CLASS="quote">Are you running a spacer right now? I hope not!</TD></TR></TABLE>
Uh, I had them put on by a wheel place and they said it'd need a spacer to fit right.
Old Dec 25, 2006 | 12:11 PM
mahatma's Avatar
i have +38mm slips w/ 215/40/16's, same springs as you, and no rubbing
sounds like the spacers may be the problem. i don't use spacers and it's all gravy
Old Dec 25, 2006 | 02:56 PM
Jesterian's Avatar
Default Re: (mahatma)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by mahatma &raquo;</TD></TR><TR><TD CLASS="quote">i have +38mm slips w/ 215/40/16's, same springs as you, and no rubbing
sounds like the spacers may be the problem. i don't use spacers and it's all gravy</TD></TR></TABLE>
Hmm, when the place tried to put the wheels on without spacers, they found that the inside of the rim was being rubbed in a spot and all the paint was ripping off. You don't have that problem?
Old Dec 25, 2006 | 03:49 PM
mahatma's Avatar
nope....that's with the 10.2" integra brakes also.
Old Dec 26, 2006 | 06:34 AM
Jesterian's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by mahatma &raquo;</TD></TR><TR><TD CLASS="quote">nope....that's with the 10.2" integra brakes also.</TD></TR></TABLE>
Crazy, I have the same brakes. I think I'll have my regular shop (not a wheel place) take a look.
diewX3
May 10, 2005 08:59 PM
whitemike1644
Jun 13, 2003 04:38 AM
hybridcivic93cx
May 22, 2002 12:50 PM
Wildohiorice
May 17, 2002 01:32 PM
