Blox B cams
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by black_EM1 »</TD></TR><TR><TD CLASS="quote">No.</TD></TR></TABLE>
You really should post your reasoning why rather than just saying 'no'. It's not very helpful.
Stock valve train cannot support the 12mm of lift.
https://honda-tech.com/zerothread?id=1803606
Plus, the vendor recommends a upgrade.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Jdmb16sir2 »</TD></TR><TR><TD CLASS="quote">anymore thoughts</TD></TR></TABLE>
sure....
x2
sure....
x2
DYNO-PRO
From: SoCal I.E 909, CA, where we innovate not immitate
Absolutely not!! That kind of lift and u are in danger of coil bind and or floating a valve which leads to catastrophic engine failure.. Anymore input needed???
Solutions
1. Fork out the money and purchase valvetrain
2. Settle for blox A's with stock valve train (which will probably serve you better anyway seeing that MOST people on HT throw the biggest cam made in their basically stock setup and then wonder why they lose a shitload of bottom and midrange power/torque
Just my opinion of course and yes I am a nobody so hey do what u were gonna do in the first place
Solutions
Definitely don't do it. I have Blox B's, had them on the stock valvetrain for a year and dropped a valve cruising on the highway. Learn from my ignorance.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Scott_Tucker »</TD></TR><TR><TD CLASS="quote">
You really should post your reasoning why rather than just saying 'no'. It's not very helpful.</TD></TR></TABLE>
Yea, I was going to get back to it, but I got busy.
I suck
I suck
Guest
Posts: n/a
Reminds me of a kid earlier this week...some known shop maybe not really honda oriented had the kid run Skunk2 stg 2 cams in his clean DC GSR well...no valvetrain upgrade was recommended by the installer or the shop...the shop said dont take it past 7k you'll be okay...it's not the RPM it's the amount of lift...the head none the less probably the bottom is history (coil bind) broken valves... atleast 8 valves gone haven't gotten into it...expensive mistake...when upgrading to an aftermarket cams it's always a good thing to swap out your used OEM valve springs and retainers for stronger and of course the right valve springs for the job...even with stg 1 cams...it's a good idea...
Please see the link I posted earlier.
That is the most definitive answer available, period.
they wanted 250 for valvesprings alone then liek 300 for the cams and all the other ****...i jsut took the guys advice and doin it right doin it once...i had the cams in lastnight but i took them all out and i put all teh springs in today so now its all done right
