need engine help with rocker arms
Old Dec 21, 2006 | 09:48 PM
hondadohc18's Avatar
Default need engine help with rocker arms
i have an 88 crx with a dohc non v-tec engine that i bought on the way home one rocker came out and the car died i went to honda and bought a single new rocker arm and talked with a tech about installing it. he made it sound simple enough so i went hme and installed the rocker but when i test drove the car it spit the arm back out. is there something i am missing or what.
Old Dec 22, 2006 | 01:53 AM
redsolturbo's Avatar
Default Re: need engine help with rocker arms (hondadohc18)
how the hell does a rocker arm come away from the main rods/shafts that hold them :?
got a pic?
Old Dec 22, 2006 | 05:03 AM
d16dcoe45's Avatar
Default Re: need engine help with rocker arms (redsolturbo)
The LS and all the non-vtec dohc Honda motors do not have shaft mounted rockers--they use a ball and stud arrarngement.
Old Dec 26, 2006 | 05:57 AM
Default Re: need engine help with rocker arms (d16dcoe45)
this is correct it is a ball and stud. it just spit the rocker right out and after replacing with a new parts it only goes about a half mile or so before doing it again. any ideas as to how this might be fixed
Old Dec 26, 2006 | 08:29 PM
Rosko's Avatar
is too much valve lash letting it fall out?? is the pocket that the ball rides in damaged? it shouldn't just fall out.
Old Dec 26, 2006 | 08:31 PM
Combustion Contraption's Avatar
This shouldnt be rocket science to figure out. Take a good look at that rocker and accompanying cam lobe and compare them to the rest, that are staying put.
Old Dec 27, 2006 | 03:10 PM
Default Re: (Combustion Contraption)
well let me tell you i dont want to sound like an ******* but i did check the lash and i compared it to the other rockers plus i have take the cam out and checked all the rocker arms and cam lobes to see if the are the same and of course they are that being my problem thats why i came on here to find if maybe there is a trick that i dont know or if i am wasting my time trying to peice this thing back togeather
Old Dec 27, 2006 | 03:44 PM
Rosko's Avatar
Default Re: (hondadohc18)
can you take a picture?
qhiggy
11
Feb 27, 2020 10:35 PM
faf2zz
Suspension & Brakes
Feb 16, 2018 06:07 PM
Edwin909
Jun 21, 2012 07:42 PM
FormulaIntegra
Jun 26, 2005 02:58 PM
