doing b16a swap in my obd-0: .. HELP !
i have been running an obd-0 b18a.i own a 1990 civic dx.mpfi ocnversion the harness is still obd-0.i have a gen2 j-spec b16a obd-1.my b18a1 has 3 sensors on the back of the block.the b16a has only 2(one being the knock sensor).. so what am i to do w/the rest of my sensor ? do i just leave them hanging and not plug them or do i have to re-wire them or what ? and what exactly are the sensors ?cannot find any info search for 2 days and still nothing.even purchased a few "recomended" honda swap-guides.still nothing.please if anyone can help its appreciated need car for work.thanks in advance.
i can send you a link form another site.it helps in a way.but ha sno info on doing the b16a swap or anything just explains what the sensor son my b18a1 are.the site says the sensors on my b18a1 are as fallows:Engine Oil Temp Switch/Engine Oil Pressure Switch & the ECT Switch.the b16a1 has only one of those and a knock sensor on the back.im confused and need to drop my motor in asap.the b16a in my car is my only means of transportation,did not plan on this problem.thanks for any help.
http://www.g2ic.com/forums/showthread.php?t=41506
89sib16
11
Dec 27, 2003 01:35 AM
