Power steering removal, what switch is this?
Old Dec 21, 2006 | 06:48 PM
redlineintegra's Avatar
Default Power steering removal, what switch is this?
Can't find it in my OEM manual for some reason, anyone? I'm about to remove all that stuff, and I'm stumped!
On a '90 DA btw.
Old Dec 21, 2006 | 07:02 PM
Default Re: Power steering removal, what switch is this? (redlineintegra)
nevermind! :
56490-PR4-013 SWITCH ASSY., POWER STEERING PRESSURE
Old Dec 21, 2006 | 07:03 PM
gsr converters's Avatar
i dont know but make sure you cap off all your lines cause if you dont your rack will start to make all kinds of bad noises then go bad, right now im at the stage of the bad noises in mine, think i might hook it back up
Old Dec 21, 2006 | 07:14 PM
Blk-dc2's Avatar
Default Re: (gsr converters)
some one said on ht that there is a power steering removal kit???? i would search it
Old Dec 21, 2006 | 07:27 PM
Default Re: (BLACK-dc2)
Yep I do plan to cap the lines, have a bit more researching to do, but I figure if I use the method pictured below, and change the fluid regularly, should be good.
Old Dec 21, 2006 | 09:51 PM
JDMorgan's Avatar
i wouldnt just cap the lines on a da. da power steering racks you can pretty much convert to manual. even on a dc/eg/ek you wouldnt really want to cap the lines, instead you would run a loop with a breather/resevior off of it. there was a thread on it on g2ic on converting your rack to manual.
http://g2ic.com/forums/showthread.php?t=88673
user 34252353
Mar 24, 2011 05:47 PM
the_branster
Jul 17, 2010 12:12 PM
vtak-maniac
Apr 23, 2010 10:28 AM
hondaboy4life
Aug 12, 2006 04:34 AM
matthewk
Nov 27, 2001 06:53 AM
