B20 Engine harness
My friends doin' a b20 swap into his car and he needs to find a b20 engine harness, I tried searchin around and stuff. I searchd the archives and the recent content on engine harnesses nothing came up.
But I can't find anything - Anybody know where I can find a b20 engine harness used OR new doesn't matter. Please help !
Thanks in advance.
But I can't find anything - Anybody know where I can find a b20 engine harness used OR new doesn't matter. Please help ! Thanks in advance.
The LS harness is the same and will probably fit better in your friends engine bay, if the car is 94-95 look for an odb1 LS harness, if it is 96+ search for an obd2 wire harness
you can also use a GSR harness, you will just have 3 plugs that do not connect
Originally Posted by crxhondata
99 crv motor are obd1 or obd2 and i dont think i need a obd0 ecu ?
A P28 is not needed for this swap, as a B20 is non vtec. A chipped non-vtec ecu will work fine if you are running OBD-1. You asked about the harness though, and for that you can't use an OBD-1 harness...search and you'll see!
Yes you can, but I don't think it will work with your engine bay plugs...you need an OBD0 ls engine harness to make everyhting work as far as I know!
