where 2 find koni yellows(shortened body) for 96 acc.??
ive hadmy GCs for almost a month and im tired of bouncin around so i need to know where to find the shortened body yellows for my car.thanx
Try ebay...I've seen several sets of them on there. Too much for a daily driven car. I'm probably going to replace my bad Tokico blues w/ the same ones...or maybe Koni Reds or KYB AGX...
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by MestizoRacer310 »</TD></TR><TR><TD CLASS="quote">Try ebay...I've seen several sets of them on there. Too much for a daily driven car. I'm probably going to replace my bad Tokico blues w/ the same ones...or maybe Koni Reds or KYB AGX...</TD></TR></TABLE>
your saying koni yellows are too much for DD? meaning theyre too stifff or.....???i keep heren use yellows so i thught that was the best for DD?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 89POS »</TD></TR><TR><TD CLASS="quote">
your saying koni yellows are too much for DD? meaning theyre too stifff or.....???i keep heren use yellows so i thught that was the best for DD?</TD></TR></TABLE>
DD? stock is best for DD.
the better question is what spring are you using?
koni do shortening and revalve for their own product, but again, i doubt that's what you looking for.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 89POS »</TD></TR><TR><TD CLASS="quote">your saying koni yellows are too much for DD? meaning theyre too stifff or.....???i keep heren use yellows so i thught that was the best for DD?</TD></TR></TABLE>
I meant too expensive...Like I said I may go w/ the Koni reds...not sure yet. Only reason I was wanting the yellows is the adjustable spring perch for ride height adjustability....and I don't plan on getting coilovers because let's face it...just HOW OFTEN will I adjust and re-adjust the height? Then to make sure the tires don't wear out prematurely I'd have to re-align the car w/ every adjustment I make. That's not happening. I wonder if the Koni Reds have that same spring perch?
i have Ground controls.all the way down in the front and 2in from the bottom of the sleeve to the adjuster.roads are soso were i live so i need some good shocks to stop from bottoming out. i ride 215 40 17s and 195 55 15s.
importdude2000
Suspension & Brakes
Jun 17, 2007 07:28 AM
Daniel_san
10
Apr 25, 2004 05:13 PM
mchuang
Feb 27, 2004 12:43 PM
