Idle Problem or Normal?
Old Dec 21, 2006 | 04:08 PM
Dealer Leaf's Avatar
Default Idle Problem or Normal?
I have a 1991 LS 2dr b18a1...My car idles at the normal rpm but when I turn the head lights on it raises, if I turn my running lights on it raises, if I turn on all my eletronics on it goes quite high up to 1900 sometimes. Could this be a result of what? Stock lights etc..
Old Dec 21, 2006 | 04:17 PM
Haleiwa-Brando's Avatar
Default Re: Idle Problem or Normal? (Dealer Leaf)
It could be a result of bad grounds, an alternator that is about shot, your idle adjustment screw being out of wack, the throttle stop screw being out of wack, the TPS sensor being out of wack, the IACV being out of wack.
Old Dec 21, 2006 | 05:49 PM
95 integra's Avatar
Default Re: Idle Problem or Normal? (Haleiwa-Brando)
It should idle up a bit to compenstate for the added load, but not past about 900rpms.
Old Dec 21, 2006 | 05:51 PM
0260MOTORSPORTS's Avatar
I agree with the GROUND or a faulty alternator..Check all the connections under the hood.
Old Dec 22, 2006 | 03:21 PM
Default Re: (0260MOTORSPORTS)
Ill check my stereo a mp grounds I think the guys at the collision center may have played with some of them
spoon93
Dec 22, 2007 08:05 AM
aziantegger10
Feb 20, 2007 01:04 PM
GqchYnAbOy
May 17, 2005 01:46 PM
-auSTIn-
10
Jun 11, 2004 03:25 PM
Doeboy
Oct 18, 2003 11:26 AM
