axles on a angle??
Old Dec 21, 2006 | 03:31 PM
keepitngga1's Avatar
Default axles on a angle??
what can be the reason for the driver side axle to be on an angle rather than straight in..its a b series in a crx..i jus replaced the axles and noticed that the axle is not completely straight..its goin on a angle toward the rear
Old Dec 21, 2006 | 03:35 PM
Bejita's Avatar
Default Re: axles on a angle?? (keepitngga1)
Thats normal. It's not supposed to be perfectly strait. Thats why you have CV joints on both ends. Drive it around and make sure there are no binds and no noises and you should be fine.
Old Dec 21, 2006 | 04:16 PM
Default Re: axles on a angle?? (Bejita)
i know its not goin to be perfect but it was definately sitting straighter before i got my axles rebuilt.
Old Dec 21, 2006 | 04:49 PM
charlee's Avatar
well getting ur axles rebuilt does not have anything due with the position they re in. the only thing that would make their position change is that if the whole position of the tranny shifts.
Old Dec 21, 2006 | 04:53 PM
Default Re: axles on a angle?? (charlee)
alright let me explain why i had to get the axle rebuilt..the lower ball joint screw fell out while i was driving therefore my supsension on the driver side collapsed..the axle was torn and seperated the axle..so im tryn to figure out if there was a possibly that sometihng was bent when this happened..i checked the lower control arm and seemed to be ok..upper balljoint was good,tie rod was good,so any ideas on why it isnt lineing up straight??
Old Dec 21, 2006 | 05:00 PM
charlee's Avatar
o ok. either ur suspension is shot foward. making it look like its going towards the rear (the cv axle) or the engine moved frotwards. check how well the wheel is aligned with the wheel well. if its fowards or back it might give u a good idea of whats going on. and also look at the engine to see if its out of place too. thats the only thing that might couse it. but since u had ur suspension brake on u. i have probably bent the frame. i dont know. many things could have happened
VTECROAR96typeR
Suspension & Brakes
Feb 21, 2009 08:27 AM
whitehf
Dec 7, 2004 02:08 PM
b18bfreak
Aug 2, 2004 10:05 AM
type Gendy
Jan 19, 2003 06:18 PM
Prelussion
Nov 15, 2001 12:51 PM
