what would be some reasons?
Old Dec 21, 2006 | 01:17 PM
rewerbcrx's Avatar
Default what would be some reasons?
what would be some reasons why my heater no longer works in my crx 91 hf?(car blower works inside just no heat)
also FYI the bottom hose returnign to radiator is not heating up the way i would like to see... already changed thermostat..
Old Dec 21, 2006 | 02:10 PM
e jay one's Avatar
Default Re: what would be some reasons? (rewerbcrx)
your heater core is probably clogged flush it out.
Old Dec 21, 2006 | 04:25 PM
rewerbcrx's Avatar
Default Re: what would be some reasons? (e jay one)
also other than the heater what would cause a cold bottom hose?
b18a engine (if need to know)
methods on how to do this?
Old Dec 21, 2006 | 06:41 PM
wiZCo's Avatar
Stouts 'n' Scotch
How long are you waiting for it to warm up? What temperature is your thermostat? You could also check the valve that opens up into the heater core to make sure it's not stuck closed. Does the engine warm up normally?
Old Dec 21, 2006 | 09:03 PM
rewerbcrx's Avatar
Default Re: what would be some reasons? (wiZCo)
i usually don't just get in and drive i let it warm some... and the temp gauge reads dead center, after warmed up ... so i don't know...
dlstech
16
Dec 12, 2012 03:04 AM
SPOON_BeIgHtEeNsEe
Honda CR-V & Element
Nov 30, 2010 01:54 PM
Circaskaterr
Feb 1, 2010 10:59 PM
nucrxowner
Jan 18, 2005 12:52 PM
simplypinoyy
23
Aug 6, 2004 03:06 PM
