is my clutch slipping?
when im going in first its normal then when i change to 2nd its goes but then the RPM revs very high when slightly stepping on gas..this only happen sometimes...is it time for a new clutch?
I've done this little test...
Pull your ebrake as high as it can go.
Depress clutch and shift into 3rd.
Release clutch w/o gassing it and the engine should cut out.
If it still trys to run, then you're in need of a new clutch.
easy test:
pop it in 6th(oh i mean 5th) while you going 20mph and floor it, see if it will grip or slip.
the best test involves driving up a hill, but since the folks in the mid west doesn't have that so us the highest gear method
Khanster
Honda Civic (2001 - 2005)
19
Sep 17, 2008 06:08 AM
