race header and reflash together a no-no
i was just browsing on hondata's website and i came across this bit of info. the hondata reflash is recomended with a stock engine or only a cai and cat back, not a race header. apparently it runs too lean and they recommend using a k-pro with a rh.
02-04 will run ok
05+ will run dangerously lean
you can get kpro or k100
also, just get a safc controller and add fuel
problem solved
problem solved
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Aco512 »</TD></TR><TR><TD CLASS="quote">i didn't know the 02-04 is safe from this?</TD></TR></TABLE>
I am also curious as to why this would be. Bump for answer
SpoolnG2
11
Jul 15, 2006 10:15 AM
