Symptoms of bad fuel pump/fuel filter
Old Dec 21, 2006 | 12:58 PM
zach1288's Avatar
Default Symptoms of bad fuel pump/fuel filter
What are the symptoms of a bad fuel pump/filter?
Old Dec 21, 2006 | 01:04 PM
poison's Avatar
Default Re: Symptoms of bad fuel pump/fuel filter (zach1288)
There are lots of symptoms, too difficult to narrow down. What issues are you having??
Some commons would be engine shutting off, lots of bogging.
Old Dec 21, 2006 | 02:04 PM
zach1288's Avatar
Default Re: Symptoms of bad fuel pump/fuel filter (poison)
My car just seems slower than when i got it(acceleration) buts it probably just me being paranoid.
Old Dec 21, 2006 | 03:29 PM
Tad's Avatar
Tad
ehhh.. need more info than that man.
check ez stuf first.
air filter, spark plugs, cap/rotor, ign. timing
Old Dec 21, 2006 | 04:01 PM
MasterKwan's Avatar
Default Re: (Tad)
Honda says replace the fuel filter when the fuel pressure drops below the set pressure. So, you need to check your fuel pressure. If it's OK then it's probably not the pump or filter. Never hurts to change the filter though.
Old Dec 21, 2006 | 04:57 PM
schardbody's Avatar
Default Re: (MasterKwan)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by MasterKwan &raquo;</TD></TR><TR><TD CLASS="quote">Honda says replace the fuel filter when the fuel pressure drops below the set pressure. So, you need to check your fuel pressure. If it's OK then it's probably not the pump or filter. Never hurts to change the filter though. </TD></TR></TABLE>
fuel filter should be changed every 15000 miles on ANY vehicle in the USA.
Old Dec 25, 2006 | 11:35 AM
Tad's Avatar
Tad
i'd say that's a bit of an exaggeration
Old Dec 25, 2006 | 12:29 PM
MasterKwan's Avatar
Default Re: (Tad)
S2000 doesn't even have a replaceable fuel filter. I mean it does but, it's in the fuel tank so, regular replacement's not in the cards.
Old Dec 25, 2006 | 12:35 PM
schardbody's Avatar
The filter should be replaced every 4 years or 96,000 km (60,000 miles), whichever comes first
per honda
i still recommend sooner than that.
Old Dec 25, 2006 | 12:42 PM
gentek1145's Avatar
how about a car bogging really badly until vtec engagement, then being fine.?
Old Dec 29, 2006 | 11:21 AM
Tad's Avatar
Tad
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by MasterKwan &raquo;</TD></TR><TR><TD CLASS="quote">S2000 doesn't even have a replaceable fuel filter. I mean it does but, it's in the fuel tank so, regular replacement's not in the cards. </TD></TR></TABLE>
interesting,
thing is, most cars have 2 filters, the normal replaceable one,
and then there is also one in the tank @ the end of the pump.
sounds like the s2k simple comes without that regular filter.
or perhaps honda located it in the tank along side the usual fuelpump filter.
Old Jan 2, 2007 | 06:39 PM
MasterKwan's Avatar
Default Re: (Tad)
Yeah, you're thinking about the sock that sits on the fuel pump. I suspect the S2000 has both the sock and the fine injector protecting filter in the tank.
dlstech
Mar 6, 2012 09:45 PM
allhonda
Oct 8, 2008 07:30 PM
junglistgsr
Nov 16, 2001 03:29 PM
