Wheel weights
Old Dec 21, 2006 | 12:22 PM
BLUE EH3's Avatar
Help we my pennies
Default Wheel weights
I have some 14in old school enkei wheels with a lip on my EK with grs brakes. The wheel weight (tapeon) is rubbing the caliper and over the time the weight falls off, can i use a metal weight(snap-on..I think its called staic balnce) thats goes on the outside on my rim?
Modified by BLUE EH3 at 3:09 PM 12/25/2006
Old Dec 21, 2006 | 03:33 PM
nsxtasy's Avatar
H-T Order of Merit
Default Re: Wheel weights (BLUE EH3)
Yes.
Old Dec 22, 2006 | 05:25 AM
SHPrelude00's Avatar
yea you can, but see if you can match balance the rim and tire assembly if you have a balancer that will show you a visual runout of both... the one we have at our shop allows you to see the physical runout of both the rim and the tire... if you do that it will limit the amount of weight on the rim...
Old Dec 22, 2006 | 04:06 PM
vtecsi00's Avatar
Default Re: Wheel weights (SHPrelude00)
you mean a piece of crap road force machine. instead of the new sonar balancer which is a much better balancer...the road force machine is not acceptable by the tire manufactures for adj.
Old Dec 24, 2006 | 11:14 PM
BLUE EH3's Avatar
Help we my pennies
Default Re: Wheel weights (vtecsi00)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by vtecsi00 &raquo;</TD></TR><TR><TD CLASS="quote">you mean a piece of crap road force machine. instead of the new sonar balancer which is a much better balancer...the road force machine is not acceptable by the tire manufactures for adj. </TD></TR></TABLE>????
BLUE EH3's Avatar
Help we my pennies
Default Re: Wheel weights (nsxtasy)
or can i grind the caliper
Old Dec 25, 2006 | 12:10 AM
vtecsi00's Avatar
that remark was for shprelude00.. do you have tape weight's on there or the clip on style??? I wouldn't grind the caliper personally. I have done it to customer's car upon there request but think it's stupid...but each to there own.
Old Dec 25, 2006 | 11:10 AM
BLUE EH3's Avatar
Help we my pennies
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by vtecsi00 &raquo;</TD></TR><TR><TD CLASS="quote">that remark was for shprelude00.. do you have tape weight's on there or the clip on style??? I wouldn't grind the caliper personally. I have done it to customer's car upon there request but think it's stupid...but each to there own. </TD></TR></TABLE> I have the tape on weight, but it rubs the caliper.. how can solve this other then gettin 15in+ wheel
Old Dec 28, 2006 | 04:41 AM
to answer the question on the kind of balancer we have im not sure that it matters to answer this kid's question, but what your talking about thats so crappy is the old school road force balancer with the big ole drum on it...the one we have is actually says 'road force harmonic', but im not sure if thats what you meant by sonar or what? (It gives all runouts, done by laser)
Old Dec 29, 2006 | 08:10 PM
BLUE EH3's Avatar
Help we my pennies
any heard of a static balnce?
Old Dec 29, 2006 | 11:17 PM
vtecsi00's Avatar
if that is the only way to avoid grinding the caliper then i would do it or get different wheels...a static balance forcrs the weight from both sides to one plain and can give you a vibration problem's but if that helps you from grinding then i would do it....see if your shop can do an alloy balance with a tack on weight and a tape weight first if not then do a static balance
bads2k
Aug 9, 2008 03:53 PM
dayaftertomorrow33
10
Feb 5, 2007 07:09 AM
todaCspec
Jun 4, 2006 02:51 AM
P@@RB@Y
Apr 30, 2006 05:30 PM
ViZ
Jan 3, 2004 08:47 PM
