How much to weld this muffler?
Old Dec 21, 2006 | 10:53 AM
invisible's Avatar
Default How much to weld this muffler?
how much would it cost to weld this integra muffler onto my civic? looks like it just needs two hangers and a pipe from the back welded on then welded onto my car.
Old Dec 21, 2006 | 11:04 AM
Andy R's Avatar
Default Re: How much to weld this muffler? (Battle23)
If you take it to a muffler shop and shoot the ish with them for a while, they will probably do it for a case of beer or $20 if they aren't too busy. If you find a guy on here that is local to you, they'd likely do the same.
Old Dec 21, 2006 | 11:52 AM
turtleman321's Avatar
shoot i wish it was the same to weld a muffler on around my house. i was quoted 100 to weld my ws2 muffler, 2 hangers, and an 02 bung. i have to take my car there to see if its possible.
Old Dec 21, 2006 | 12:11 PM
RCautoworks's Avatar
Looks like there is barely any pipe, so its not going to be just a weld up job. You will have to add either a smaller piece to slip in there, or a larger piece to go over, or you can use a hole saw to cut a new hole and start all over.
Old Dec 21, 2006 | 12:18 PM
invisible's Avatar
Default Re: How much to weld this muffler? (90blackcrx)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 90blackcrx &raquo;</TD></TR><TR><TD CLASS="quote">Looks like there is barely any pipe, so its not going to be just a weld up job. You will have to add either a smaller piece to slip in there, or a larger piece to go over, or you can use a hole saw to cut a new hole and start all over.</TD></TR></TABLE>
Hum, a larger pipe over seems to be the easiest and cheapest way. It's going on my beater so i dont really care much about it aslong is doesnt fall off heh.
Old Dec 21, 2006 | 02:52 PM
CivicVX94's Avatar
that muffler is beat to hell...why don't you just buy an axle back and call it a day if all you want/need is a new muffler? i would think it would cost only slightly more and IMO would look better, and probably sound better.
Old Dec 21, 2006 | 03:06 PM
thermal's Avatar
If you were closer to me, I'd do it for $50, installation included.
Old Dec 21, 2006 | 05:57 PM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Battle23 &raquo;</TD></TR><TR><TD CLASS="quote">
Hum, a larger pipe over seems to be the easiest and cheapest way. It's going on my beater so i dont really care much about it aslong is doesnt fall off heh. </TD></TR></TABLE>
Yes, but that section on that muffler is pretty thin, in the long run it will probably crack in that area. I myself would get a new muffler.
r1ch
Mar 12, 2009 03:31 PM
2ndgent3g
Apr 21, 2007 11:13 PM
Type Wah
Dec 20, 2005 11:11 AM
ibe2fly
May 12, 2004 06:00 PM
steve_s
Jan 19, 2003 04:59 PM
