D16y7 wont start
Old Dec 21, 2006 | 08:26 AM
4NOWJUSTADX's Avatar
Default D16y7 wont start
blew my old dx motor and swapped a 99lx motor in. everything is connected and i know that it is getting spark and fuel and the motor turns over fine, but it will not run.i have the distributor matched to TDC but i'm unsure of the plug wires proper position. a picture, diagram. or good description would really help. thanks
Old Dec 21, 2006 | 08:46 AM
Archidictus's Avatar
Unceasing Measure
Default Re: D16y7 wont start (4NOWJUSTADX)
Old Dec 21, 2006 | 09:04 AM
Default Re: D16y7 wont start (Archidictus)
I have the plugs in the right order. I'm getting pressure at the fuel return line so i should be getting pressure at the injectors right? my check engine light does NOT stay on. Any suggestions?
Old Dec 21, 2006 | 09:45 AM
Jakester9500's Avatar
so are you saying that it turns over, and doesn't start, or that it turns over, fires up and then shuts off?
Old Jan 21, 2007 | 07:44 PM
275Performance's Avatar
Default Re: (Jakester9500)
I am having this EXACT same problem. Every fine a fix?
Old Jan 21, 2007 | 08:00 PM
VRD^don's Avatar
Default Re: (275Performance)
check your grounds...i had fuel/spark...had a trans ground but didnt have a VC ground...put one on and she started right up..
Old Jan 21, 2007 | 08:26 PM
Default Re: (k_motor)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by k_motor &raquo;</TD></TR><TR><TD CLASS="quote">check your grounds...i had fuel/spark...had a trans ground but didnt have a VC ground...put one on and she started right up..</TD></TR></TABLE>
I've got trans ground, and the ground that runs from the head to the chassis.
Should the one from the head be moved to valve cover?
Old Jan 21, 2007 | 08:50 PM
EX-T's Avatar
There's also a harness ground that goes to the thermostat housing.
Old Jan 22, 2007 | 07:44 AM
Default Re: (EX-T)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by EX-T &raquo;</TD></TR><TR><TD CLASS="quote">There's also a harness ground that goes to the thermostat housing.</TD></TR></TABLE>
Yea thats there too. Sorry forgot to mention.
mikeyg1995
Apr 22, 2012 07:38 PM
REDEM1FTW
18
Nov 6, 2010 06:08 AM
michaeljenkins
Apr 26, 2008 11:51 PM
skribblez
12
Aug 27, 2006 05:51 PM
[626]95-GSR
30
Feb 16, 2002 12:06 PM
