V6 ENGINE ON ODYSSEY EXL
Old Dec 21, 2006 | 07:02 AM
AllMotorDan's Avatar
Default V6 ENGINE ON ODYSSEY EXL
Cylinder 5 misfires on heavy load, swapped ignition coils, swapped spark plugs, swapped injectors, checked for continuity in ignition coil connector, measured voltage in coil connector, adjusted valves, did cylinder leakdown and compression test, swapped pcm....What could the problem be?
Old Dec 21, 2006 | 08:42 AM
no suggestions?
Old Dec 21, 2006 | 09:06 AM
b19coupe's Avatar
Default Re: (AllMotorDan)
Sounds like you have tried just about everything. Possible problem with the EGR system?
Old Dec 21, 2006 | 10:30 AM
Combustion Contraption's Avatar
Does this engine have variable cylinder management?
Old Dec 21, 2006 | 10:51 AM
yes, we've tried about everything. we just did the fuel pressure check. went for a test drive and did a snap shot of the system. i guess we gotta call the professional honda-techs up
Old Dec 21, 2006 | 10:57 AM
You mean Tech Line? LOL, theyre just going to use you for R&D. I bet you one of the rockers on the 'dead' bank of cylinders is whats giving you trouble.
it has vcm but supposively it only affects bank2 and not 1. btw i work at honda and we're trying to figure it out. all the techs bust my ***** for coming on here and i just wanted to see what your opinions on this was. thanks a lot
Old Dec 21, 2006 | 11:05 AM
tech line said to keep checking crap, worn cam lobe, crankshaft end play, etc. hmmm
Old Dec 21, 2006 | 11:18 AM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by AllMotorDan &raquo;</TD></TR><TR><TD CLASS="quote">tech line said to keep checking crap, worn cam lobe, crankshaft end play, etc. hmmm</TD></TR></TABLE>
What did i tell ya! R&D!
Old Dec 21, 2006 | 11:25 AM
yeah, thanks for your input. you proved to some of the techs here theres people out there on this forum with knowledge other than what springs should i get for my car or what intake is best haha
Old Dec 21, 2006 | 12:04 PM
we figured it out....Cam Lobe was shot! it worn down about a 1/4 of an inch. pretty crazy
Old Dec 21, 2006 | 12:06 PM
Now to figure out why that lobe took a ****.
Old Dec 21, 2006 | 07:48 PM
Cory man's Avatar
Default Re: (Combustion Contraption)
Ill have to remember this post in case this becomes more of a problem. TIA.
Gotta love warranty work!
Old Dec 22, 2006 | 06:48 AM
haha yeah warranty work ftw
Old Dec 22, 2006 | 07:16 AM
PyroProblem's Avatar
Did compression readings differ with worn cam lobe?
Old Dec 23, 2006 | 05:57 AM
no it did not. after clearing the mil the only time the mil would come back on was under heavy load/full throttle.
wanda robinson
Mar 18, 2017 08:25 AM
djcurtis59
Honda Civic (2001 - 2005)
Jul 4, 2011 12:51 PM
itr1235
May 30, 2007 04:34 PM
LSVTEC 91 Civic
25
Jul 12, 2004 01:49 AM
