V6 ENGINE ON ODYSSEY
Cylinder 5 misfires on heavy load, swapped ignition coils, swapped spark plugs, swapped injectors, checked for continuity in ignition coil connector, measured voltage in coil connector, adjusted valves, did cylinder leakdown and compression test, swapped pcm....What could the problem be?
itr1235
May 30, 2007 04:34 PM
