anybody ever used 15-50 mobil synthetic??
Old Dec 20, 2006 | 11:16 PM
shirazi89's Avatar
Default anybody ever used 15-50 mobil synthetic??
anybody ever used 15-50 mobil synthetic????????
Old Dec 21, 2006 | 04:54 AM
95 integra's Avatar
Default Re: anybody ever used 15-50 mobil synthetic?? (shirazi89)
Yes, turbo GSR and SR20DET only though.
Old Dec 21, 2006 | 10:01 AM
shirazi89's Avatar
some 1 told me i should use it on my stock gsr....is that bad?
Old Dec 21, 2006 | 10:04 AM
Blk-dc2's Avatar
Default Re: (shirazi89)
damn that sound thick as hell!!
Old Dec 21, 2006 | 10:10 AM
95 integra's Avatar
uh....try more like 5w30 for a stock/lightly modded gsr.
Old Dec 24, 2006 | 08:50 PM
shirazi89's Avatar
Default Re: (95 integra)
wat if i have already added 15-50 ...should i drain it and add some 10-30?
Old Dec 25, 2006 | 03:38 AM
vladd's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 95 integra &raquo;</TD></TR><TR><TD CLASS="quote">uh....try more like 5w30 for a stock/lightly modded gsr.</TD></TR></TABLE>
not only stock and lightly modded, but i always heard that 5w30 works just fine on a turbo'd motor.
Old Dec 25, 2006 | 03:40 AM
vladd's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by shirazi89 &raquo;</TD></TR><TR><TD CLASS="quote">wat if i have already added 15-50 ...should i drain it and add some 10-30?</TD></TR></TABLE>
i would; 10-30 or 5-30 would work. owner's manual calls for 5w30, 15w50 is quite a ways off.
Old Dec 25, 2006 | 08:58 AM
hindsonher's Avatar
Default Re: (civicdxtyper)
5w-30! not sure if you actually need that kind though. I once added the wrong oil to my car (stupid), but i drained it right away and put in the right kind.
Old Dec 30, 2006 | 01:36 PM
shirazi89's Avatar
so should i go wit 5-30 or 10-30?
Old Dec 30, 2006 | 01:43 PM
nsxtasy's Avatar
H-T Order of Merit
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by shirazi89 &raquo;</TD></TR><TR><TD CLASS="quote">so should i go wit 5-30 or 10-30?</TD></TR></TABLE>
The owner's manual and service manual specify that 5W30 is preferred at all temperatures.
By "added", if you mean that you had 5W30 (or 10W30, which is also acceptable at temperatures above freezing) and you only added, say, a quart of 15W50, then it's probably still close enough to the recommended viscosity that you don't need to drain it. But if you did an entire oil change with 15W50, that's a different story.
jonnytapia
Jan 12, 2008 09:27 PM
Turbo-charged
Mar 10, 2007 06:46 AM
VisualAutoMotoring
Nov 28, 2004 03:39 PM
Elvis1977
Nov 11, 2003 09:02 AM
