Bought used clutch for the R tranny.
im in the process of changing my clutch. THE clutch on it now is HISTORY
anyhow i bought a used toda clutch kit wiht lightweight flywheel was seeing if you guys can tell from the pictures below if the clutch disc looks reusable and the flywheel? does the flywheel look like it will need to be resurface?
Ive also bought an exedy stage one kit just in case. that includes the clutch disc, pressure plate, Throw-out Bearing, ACT Pilot Bearing,Alignment tool
Thanks Pat, any info would happily appreciated.
that pressure plate and flywheel look fucked up. wayyyyyy to many hot spots on both.......hope you didn't pay much for that stuff.......looks like a really expensive paper weight......
although you can probably have the flywheel machined........but that pressure plate is junk.....and if that is the disc that came with it I'm sure its toast too.
that pressure plate and flywheel is warpped clutch looks like its gone also... like nonvtec said hope you didnt pay much for it!..
if your wanting to sale this stuff.. I have a guy that buys JUNK... doesn't matter what it is... pm for info he'll probably buy it off you..
Nahh didnt spend more than 150. basically just paid for the flywheel.
I dont know clutches like that so i wouldnt know whats bad or not. asked here, you guys know whats toasted, warped, bad then and this the clutch is done? the flywheel looks alright, maybe getting it resurfaced would make it worth wat i spent?
thanks for the input
DEFINITELY RESURFACE IT
it's not that big of a deal,
and honestly, if you're swapping parts around you're going to want to resurface anyways.
I tried reusing my pressure plate without resurfacing it, it looked fine, but I've had problems on cold starts with it.
urs looks funny, but it'll be just fine once resurfaced.
do the pp and flywheel and u should be good to go.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Bense »</TD></TR><TR><TD CLASS="quote">wow</TD></TR></TABLE>
i dont know why but that made me laugh so hard...
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Mr. HYDE »</TD></TR><TR><TD CLASS="quote">first off never buy a used clutch. second just have the flywheel resurfaced and get yourself a new clutch</TD></TR></TABLE>
thanks for the info. well it was toda, either way huh, i thought atleast the flywheel could be worth it
I did bought the exedy organic stage one clutch, ill have the resurfaced flywheel with this setup.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by brick top »</TD></TR><TR><TD CLASS="quote">that exedy will work nice with that flywheel. that is of course after proper break in.
THanks, can't wait to replace the clutch, im sighest. The clutch that came with my swap was a piece of junk. Overkill, harsh engagement, high revs to get it going. I was told it was a guriella clutch. Dont know what the japs was thinking
you can normally get away with buying used flywheels, but i would stay away from clutches for the future. im sure a local napa can resurface that flywheel quick. napa here in NY charged me 30 bucks
methanemotorworks
Feb 13, 2006 07:32 PM
