Throttle Position Sensor
Old Dec 20, 2006 | 04:31 PM
egreenmachine's Avatar
Default Throttle Position Sensor
Pick up a lsvtec setup for my hatch and TPS is broke off, need help on how to replace since its riveted or is it just easier to replace the throttle body?
Old Dec 20, 2006 | 06:46 PM
hondamark35's Avatar
Default Re: Throttle Position Sensor (csxcx)
easier to find a TB. they are cheap and easy to put on. personally i wouldn't recommend an aftermarket or oversized one, but do what you want...
Old Dec 20, 2006 | 08:09 PM
Rahjahdat's Avatar
Yeah it would be easier to replace just the throttle body,but, if money is a problem you can always get a dremel, make slits in them as if you were to screw it out like a flat head. Don't bother calling the dealership asking if they sell just the sensor alone, they're going to sell you the whole manifold. Just search around eBay or the for sale threads, think they should only cost about 20 bucks a pop. Somebody correct me if i'm wrong, I think most D-series and B-series Throttle Position Sensors are interchangeble. Good luck.
Old Dec 20, 2006 | 10:24 PM
DB1_559's Avatar
Default Re: Throttle Position Sensor (Rahjahdat)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Rahjahdat &raquo;</TD></TR><TR><TD CLASS="quote">Yeah it would be easier to replace just the throttle body,but, if money is a problem you can always get a dremel, make slits in them as if you were to screw it out like a flat head. Don't bother calling the dealership asking if they sell just the sensor alone, they're going to sell you the whole manifold. Just search around eBay or the for sale threads, think they should only cost about 20 bucks a pop. Somebody correct me if i'm wrong, I think most D-series and B-series Throttle Position Sensors are interchangeble. Good luck.</TD></TR></TABLE>
wat he said
Old Dec 21, 2006 | 12:16 PM
Default Re: Throttle Position Sensor (jdmboi86)
Thanks everyone, I was expecting the "search" answer
TASAuto.com
Performance
Jul 19, 2009 05:35 PM
oz`Vtec
Feb 18, 2005 03:51 AM
ALLMOTOR ARUBA
Jun 6, 2004 06:16 AM
alkeener
Oct 26, 2003 07:25 PM
Inaniac
Oct 21, 2002 12:34 AM
