HELP WITH MY 87 CRX SI!!!!!
Old Dec 20, 2006 | 04:16 PM
redrexracer's Avatar
Default HELP WITH MY 87 CRX SI!!!!!
hello all! my rex is acting up. ill go to drive and when i stop or let off the gas the idle drops and the car dies. it only does this every so often but its a daily occurance. also i noticed that while at idle in my driveway it will idle very low and rough and almost die. and if i pump the brake the idle goes up to normal until i stop pumping the brake. its friggin wierd. when im in my drive way at idle it wont die though its only when i drive. any suggestions? comments? help? im kind of at a loss. thanks alot.
Old Dec 20, 2006 | 04:41 PM
Gustav129's Avatar
Default Re: HELP WITH MY 87 CRX SI!!!!! (redrexracer)
I won't be able to help you since I am new to all this, but it's nice to see a 1g/3g on this forum. 3g Civic Si here.
Old Dec 20, 2006 | 08:43 PM
firstgen85's Avatar
Whats up man? I drive a 85 crx with a full fuel injection swap from an 87 si crx. I t sounds to me like you might either have a vacuum leak or something is wrong with your electrical system. Does the vehicle start up fine? Does your idle jump when the vehicle is not moving or is it just idleing low? Maybe if you could be a little more thorough with the problem and what it is doing I could help you out. First gen for life!
Old Dec 20, 2006 | 11:16 PM
Default Re: HELP WITH MY 87 CRX SI!!!!! (firstgen85)
well i have to mess with the ignition switch like push up or down on the key while i turn it and even then it takes a couple tries to start it and when i hooked up a battery charger is was drawing like 6 amps which is bad. and once it was charging the car would start on a dime. so i think it might need an alternator. no the idle doesnt jump but sometimes on start up it will idle slightly high or normal but once i step on the pedal it goes low and rough.
Old Dec 22, 2006 | 08:29 AM
Gustav129's Avatar
Well, if you have to pump the brakes to kill the rough idle, I'd look at vacuum line to the brake booster. or the brake booster itself. Somewhere, there is vacuum being lost.
BTW, if it's a manual, you can always push start it. It's fun to do buy yourself, it makes it more of a challenge.
Old Dec 22, 2006 | 08:38 AM
alcapone's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by redrexracer &raquo;</TD></TR><TR><TD CLASS="quote">well i have to mess with the ignition switch like push up or down on the key while i turn it and even then it takes a couple tries to start it and when i hooked up a battery charger is was drawing like 6 amps which is bad. and once it was charging the car would start on a dime. so i think it might need an alternator. no the idle doesnt jump but sometimes on start up it will idle slightly high or normal but once i step on the pedal it goes low and rough.</TD></TR></TABLE> yea thats what i would say would be alternator
2ndgenaccord
Classic Hondas
Jan 20, 2013 12:57 PM
hellraiser7492
Jun 6, 2009 09:12 AM
krysted9354
Classic Hondas
Jun 4, 2009 04:49 AM
newman271
May 29, 2006 07:28 PM
roterx7
Feb 20, 2006 07:41 PM
