5 Lug question?
Old Dec 20, 2006 | 03:45 PM
JDM_EK4_Coupe's Avatar
(banned)
Default 5 Lug question?
What brake master cylinder can I use? Are all of the ones off integras 15/16, I also know I need the SI prop valve and would Civic SI E-Brake lines instead of CTR?
Old Dec 20, 2006 | 03:55 PM
(banned)
Default Re: 5 Lug question? (JDM_EK4_Coupe)
Also, would Civic SI rear brake lines fit too?
Old Dec 20, 2006 | 06:19 PM
impact_blu's Avatar
I have 5 lug on my eg and I have a itr mc/bb on, bolts right on. As for the prop valve, go with a non abs 4040 from a 90-93 integra rs. For the break line, I just used the one that came off the type r. good luck with your swap.
Old Dec 20, 2006 | 06:42 PM
JDM-EJ698's Avatar
Default Re: 5 Lug question? (impact_blu)
All SI brake lines will work fine.You need SI E-Brake cables(if you dont have rear discs).I left all my original MC/BB.Everything has been fine for over a year.just make sure you bleed it right.I have 98 civic HB n I found out that all civic 96-00 have the same part # for the prop valve.(exept EX model)
Old Dec 20, 2006 | 06:46 PM
(banned)
Default Re: 5 Lug question? (JDM-EJ698)
Old Dec 20, 2006 | 08:36 PM
Aquafina's Avatar
I'm still on DX MC and prop. Works great on track.
litoekneeil
Suspension & Brakes
May 5, 2009 10:58 AM
hYbRid_Eg6
Apr 3, 2009 01:48 PM
Cold Fyre
Jun 25, 2006 09:45 PM
hondacivichatch
Jan 19, 2006 03:41 PM
midnightdarknes5
26
Jun 15, 2004 06:26 PM
