how do i get tranny off the motor?
cant get the tranny off my 94 gsr. wouldnt the tranny come off the motor if i just take off all the bolts? any tricks in taking it off?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by jikespingleton »</TD></TR><TR><TD CLASS="quote">cant get the tranny off my 94 gsr. wouldnt the tranny come off the motor if i just take off all the bolts? any tricks in taking it off?</TD></TR></TABLE>
it sits on dowel pins..you gotta pull it off just straight out once all the bolts are loose...Is there no free play in it at all??
Yeah u gotta make sure all the bolts are out, then u can pull it out from the motor. Theres a couple of small bolts on the bottom of the tranny to that u gotta take off.. just make SURE u got all the bolts off then the tranny will come off no problem.
does anybody know exactly how many bolts im sposed to take out. ive got the big ones out fromt he bell housing and the lil ones holdin the lil brakets on the bottom of the motor. any other bolts?
The BIG ones in the rear by the fire wall, the 19mms that go through the T bracket. Then 2 on top, few on the front side and those little ***** underneath.
Did you take the mount off the top? haha. Generally it "cracks" when you have all the bolts out and you wiggle on it just a tad. If its still solid, then theres most likely something still holding it in. Did you get the bolt in the front that is reversed and threads into the tranny?
could be your problem!jhust incase...good luck! if not yank as much as you can!
