car overheating. please help.
Old Dec 20, 2006 | 03:12 PM
gsrcivic619's Avatar
Default car overheating. please help.
97 civic stock single cam motor. My car had been overheating so i went ahead and removed the thermostat. That didn't work, still overheating. Fan turns on just fine. Top hose is always boiling hot. There are no leaks that i can see when i fill it up with coolant, yet the radiator will be pretty empty by the next 2 days or so. After i fill it with coolant and water the car stays cool for about half a day, after that it heats up badly. Could this be a clog somewhere? Any ideas or suggestions would be greatly appreciated. Thanks guys.
Old Dec 20, 2006 | 03:13 PM
Syndacate's Avatar
How's the bottom hose when the engine is hot?
Old Dec 20, 2006 | 03:24 PM
MasterKwan's Avatar
Default Re: (Syndacate)
Most likely a head gasket issue. If it's not leaking on the ground, it's probably going out the tailpipe. You could also have a high pressure leak too. You may want to get it pressure tested.
Old Dec 20, 2006 | 03:26 PM
bottom hose stays cool maybe a tiny bit warm, but top hose is very hot.
Old Dec 20, 2006 | 03:31 PM
Perfectionist's Avatar
Default Re: car overheating. please help. (gsrcivic619)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by gsrcivic619 &raquo;</TD></TR><TR><TD CLASS="quote">97 There are no leaks that i can see when i fill it up with coolant, yet the radiator will be pretty empty by the next 2 days or so. After i fill it with coolant and water the car stays cool for about half a day, after that it heats up badly. </TD></TR></TABLE>
Well, the cooling system needs coolant to funtion properly. If the coolant is disapearing, the engine will run hotter. You need to determine where the coolant is going. As previously mentioned, it may be a blown head gasket, unless you have an external leak you haven't detected yet.
Old Dec 20, 2006 | 03:35 PM
Default Re: car overheating. please help. (Perfectionist)
I really hope it isn't a blown head gasket.. when you guys mention "external leak" what exactly are you guys referring to? How can i check for an external leak? And what's a quick way to check for a blown head gasket? Any other suggestions as of why my car might be overheating? As weird as this may sound, sometimes it leaks and sometimes it doesn't. True story. (from the bottom of the radiator where the bottom hose is.
Old Dec 21, 2006 | 12:24 PM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by gsrcivic619 &raquo;</TD></TR><TR><TD CLASS="quote"> As weird as this may sound, sometimes it leaks and sometimes it doesn't. True story. (from the bottom of the radiator where the bottom hose is.</TD></TR></TABLE>
Well now, there is your external leak. Honestly, I don't know why you keep asking about this problem when you have all the evidence and answers.
Old Dec 21, 2006 | 12:57 PM
MasterKwan's Avatar
Because many people who post here are helpless and need to be told what to do.
Old Dec 21, 2006 | 12:59 PM
jdmjaser's Avatar
Default Re: car overheating. please help. (MasterKwan)
air bubble in the line?? maybe??
caitb
Apr 26, 2015 06:22 PM
chai_ek9
24
Jul 18, 2009 05:39 AM
snowblind7x
Feb 21, 2007 08:58 PM
Roi
15
Nov 20, 2005 03:52 AM
