need help on new clutch
search or get a repair manual. basicly take off the tranny starter axles drain trany fluid. thats actually backwards. then take off pressure plat and old clutch and put on new one put tranny back on. of course there alot more to it then that but im done.
have you ever replaced a clutch on any vehicle? I ask this because it does take time and knowlage about how everything works. Like deadman said your best bet would be reading a well know repair manual. We are here to help you in any technical questions you come across that requires our experience. hOW MANY MILES DO YOU HAVE ON THE VEHICLE?
ok i am going to try to remeber everystep
1. remove battery
2. remove axles and halfshaft.. (if you never did this you going to need help)
3. drain tranny fluid
4. remove shiftlinkage
-- if you can;t get the pin out you can remove the bolt on tranny side
-- and the bolt on the bottom of the shifter leaving half the shift linkage on the
-- tranny
5. remove starter
6. place jack under motor to support it (use a wooden block)
7. remove mount complete
8. take off slave cylinder .. take the 2 bolts off not the lines.. also remove the
---screws that support the line
9. remove all bolts.. you will have to brackets at the bottom and a shield to remove..
10. pull tranny down!!!!!!!
that get the tranny off.. someone want to pick up from here?
1. remove battery
-- tranny
5. remove starter
