HT's OFFICIAL front wheel/brake combo thread!
dont know if this has been done yet , if it has sorry. but id like to see peoples wheel/caliper/rotor choices. post up offsets and sizes and whether or not u have to use spacers. lets see all the combos out there!
my current
16x7 spoon sw388 -38 offset with no spacer. spoon twinblock caliper with a brembo rotor.
what once was
15x7 desmond regamaster evo -38 offset with a stock itr 5 lug caliper and a brembo rotor.
Modified by ATS*Mark at 4:26 PM 12/25/2006
my current
what once was
prolly considered weak but
17X7.5 advan Rgs +42, brembo slotted rotors, stock brakes, ebc green stuff pads, gorilla lugs, no spacers
Modified by nathanong87 at 2:07 PM 12/21/2006
Here's my setup; will post a better picture later.
Wheel Choices:
Spoon Sports SW388 16x7 4H100 +45 Offset (Mugen Lugnuts)
Yokohoma Super Advan SA3R 15X6.5 4H100 +42 Offset (Mutaki Lugnuts)
Setup:
H&R 5mm Inner Wheel Spacer
4H100 Spoon Sports Front Rotors
Spoon Sports Calipers
NOTE: When using this setup you are very limited to wheel selection in size 15".
Wheel Choices:
Setup:
OEM 14" HX's semi polished, Now running on 195/60 Azenis RT215. 5mm H&R spacer, Skunk2 extended studs. Ricer "Brembo" x-drilled slotted rotors. Si Calipers+crappy AEM pads. Should be Brembo blanks + HP+'s soon.
My basic setup...will be upgrading this winter though!
Dunlop FM-901's 205/45/16
Powerslot Rotors
Hawk HP Pads
Goodridge SS Brake Lines
Spoon Calipers
JDM ITR's 16" in Gunmetal
16x7 +45 Desmond Regamaster EVO's
More wheel choices will be coming for next summer
Powerslot Rotors
Hawk HP Pads
Spoon Calipers
Hell yeah boy^ amd cool thread idea Mark.
Mine is the poor man combo
Old street set up
street=17x7 1/2 Rays Gramlights w/ sticky Kuhmo MX, Hawk HPS + pad, blank Brembo rotor and Motul fluid
Now it is Si wheels on Azenis 615 for the street ( im sure you ll know what that looks like and Kuhmo Victorracer on 15x7 no name specials for the track (brake setup remains the same)
The best brake set up w/ out changing your stock Honda calipers is a good biting pad, cheap blank rotor and some high temp fluid.
Old street set up
Kosei K1 +45 w/ azeni rt-615s
Stock Calipers w/hawk HP+ and Brembo blanks
No spacers. Just wondering would spacers be dangerous on the track with stock lug nuts?
I miss my TE37s!
16x7 +42
205/40/16 tires
Stock Integra disc/brakes
Zenkie Lugnuts (Were red before, haha)
Current:
Stock CTR 5-Lug disc/brakes swap
JDM ITR 16x6.5 Rims +50
205/40/16 Tires
Rays Engineering Lugnuts
16x7 +42
205/40/16 tires
Current:
205/40/16 Tires
