$5 Sent Via Paypal to the person that finds my problem out!
Old Dec 20, 2006 | 11:29 AM
Scott (T.O.A)'s Avatar
Default $5 Sent Via Paypal to the person that finds my problem out!
i getting desperate now the winter here is damn cold and i need to drive again lol!
the person that gives me the info that fixes my problem gets $5 via paypal!
basically this is the story,
blew my old d16z6 up - replaced it with another d16z6. used the old tranny and shafts ect.
got the swap in and it starts, drove the car to a local shop to get the tracking done. was driving fine until all of a sudden the revs dont die. If i put the car in nutural the car still revs (at about 3k at the time).
so i carry on driving to the shop having to kill the car every time i stop at lights ect for fear of ******* my new engine!
when i started the car up again the revs would still be at 3k, i then carried on driving and was driving up to 4k revs. then the car sticks a 4k revs when idle. the car still pulls like the engine is revving high when in gear.
after leaving the car for about 1 hour the revs idle normal, give the engine a slight rev... it happens all over again
any ideas people!!
scott
Old Dec 20, 2006 | 11:34 AM
inline4's Avatar
Default Re: $5 Sent Via Paypal to the person that finds my problem out! (Scott (T.O.A))
make sure you bled your coolant the correct way, make sure the vent is on heat when you refill it.
take off your IACV and clean it with some throttle body cleaner
make sure your vacuum hoses are all plugged up and there are no leaks in the throttle body or intake manifold
i'm thinking it's coolant related or IACV.
maybe it's something simple like your throttle cable is too tight or it's catching on something.
Old Dec 20, 2006 | 11:36 AM
Savage211's Avatar
Check your throtle body.. sounds like it's just sticking... force it closed. then see if it does the same thing.
If it's idleing fine, grease the throtle return... where the cable twists the throttle body open and closed.
good luck
Old Dec 20, 2006 | 11:37 AM
gabebauman's Avatar
I know a fella with the same problem but on his gsr swapped civic. He said something about a coolant hose leak. I'll see if he's figured it out.
Old Dec 20, 2006 | 11:38 AM
Savage211's Avatar
Default Re: $5 Sent Via Paypal to the person that finds my problem out! (Savage211)
Oh ya, you can pm me for my paypall account. haha.
thanks for the quick reply im gonna go check the throttle body now.
just wondering what the iacv is and what it looks like?
Old Dec 20, 2006 | 11:44 AM
inline4's Avatar
Default Re: (Scott (T.O.A))
its on the back of the intake manifold near the firewall, can't miss it, it's a cylindrical looking thing held onto the intake manifold by 2 "12's"
Default Re: $5 Sent Via Paypal to the person that finds my problem out! (gabebauman)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by gabebauman &raquo;</TD></TR><TR><TD CLASS="quote">I know a fella with the same problem but on his gsr swapped civic. He said something about a coolant hose leak. I'll see if he's figured it out. </TD></TR></TABLE>
thinking about it there is a small leak coming from a hole in the engine (looks like a bolt should be in it) at the bottom of the plastic cam gear cover.
Old Dec 20, 2006 | 11:46 AM
gabebauman's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Scott (T.O.A) &raquo;</TD></TR><TR><TD CLASS="quote">Just wondering what the iacv is and what it looks like?</TD></TR></TABLE>
Old Dec 20, 2006 | 12:01 PM
instructor74's Avatar
thinking about it there is a small leak coming from a hole in the engine (looks like a bolt should be in it) at the bottom of the plastic cam gear cover. </TD></TR></TABLE>
That sounds like the weep hole for the water pump and if it is you will need to replace the water pump. To bad you didn't do that and the timing belt when the engine was out of the car
Old Dec 20, 2006 | 12:19 PM
Chrisfrom1986's Avatar
Default Re: (gabebauman)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by gabebauman &raquo;</TD></TR><TR><TD CLASS="quote"></TD></TR></TABLE>
In addition, check to make sure your TPS isnt bad.
Old Dec 20, 2006 | 01:38 PM
YoungKadafi's Avatar
you say its cold? make sure your coolant hoses are correctly hooked up, replace PCV valve and oil filter.... oil filter and PCV valve fixed my exact same problem. Then deep creep the crap outta the TB..
actually deep creep the Throttle body 1st, then change oil/filter/PCV valve. and fix that leak
Old Dec 20, 2006 | 01:45 PM
CivicGSRsi's Avatar
Default Re: (YoungKadafi)
My car used to do that all the time and it was b/c i had way to much pressure in my ac.. so i let it all out and it stoped thats what fixed my car "it was a 1999 i4 cougar" g35infiniti20 =aim
Old Dec 20, 2006 | 02:18 PM
RyanA's Avatar
Default Re: (CivicGSRsi)
I'd say the "donut" in the Thermo idle control valve (or whatever the heck it's called) has backed out. It's under the throttle body. Easiest way to get to it is pull the TB off and it's the piece that has either 1 or 2 coolant lines hooked to it. Remove the 2 8 mm screws that hold the metal cover on. When you pull the cover off, see if the donut will screw in. If it moves at all, use 2 straight screwdrivers to screw it in as far as you can. Put it back together and make sure your coolant is full. Start the car and see what happens when you get up to operating temp.
Old Dec 20, 2006 | 03:15 PM
gezzuzz's Avatar
check vacuum hoses
Old Dec 20, 2006 | 03:16 PM
Syndacate's Avatar
Doesn't sound like the IACV or FITV.
I'm in agreement for throttle body - check it. Sounds like your butterfly is sticking.
(BTW: If that's what it is I do not want any money of any kind as I'm just not into that **** - it's a tech forum, should be used to help people for free - there's no charge, that's just gay :-\)
Old Dec 20, 2006 | 03:23 PM
Archidictus's Avatar
Unceasing Measure
Default Re: (Syndacate)
Could also be a raging boner of a vacuum leak.
Old Dec 20, 2006 | 03:25 PM
inline4's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Syndacate &raquo;</TD></TR><TR><TD CLASS="quote">Doesn't sound like the IACV or FITV.
(BTW: If that's what it is I do not want any money of any kind as I'm just not into that **** - it's a tech forum, should be used to help people for free - there's no charge, that's just gay :-\)</TD></TR></TABLE>
WORD, i wouldn't accept money even if I went to help you personally, a BEER will suffice
Knowledge is power, and we're not an electricity company. lol
Old Dec 20, 2006 | 03:49 PM
why wouldnt you accept a $5 paypal transfer. It will be 4.13 after the fees removed, which will then cover 2 Junior bacon cheese burgers, 1 five piece nuggs, and maybe a drink, or if your more into mcdonnals, you could ask ronnald too hook up a number 1.
Old Dec 21, 2006 | 05:59 AM
specv5150's Avatar
because people arent gay. You can find $5 in your couch cusions or in the jeans you wore last week that are in teh dirty clothes hamper
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by YoungKadafi &raquo;</TD></TR><TR><TD CLASS="quote">why wouldnt you accept a $5 paypal transfer. It will be 4.13 after the fees removed, which will then cover 2 Junior bacon cheese burgers, 1 five piece nuggs, and maybe a drink, or if your more into mcdonnals, you could ask ronnald too hook up a number 1.</TD></TR></TABLE>
Old Dec 21, 2006 | 06:09 AM
92redhatch's Avatar
the answer to your problem is ( My cousins car had the same problem) Your throttle cable is toooooooo tight. Thats why when you accelerate it stays at whatever rpm you left it at. And if you put your foot under the accelerator pedal and pull up it will bring the rpms down again.
Trust me just loosen the nut by the intake manifold where you can adjust the throttle cable and call it a day.
keep your 5 bux.
Old Dec 21, 2006 | 06:30 AM
boynblue's Avatar
Default Re: (92redhatch)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 92redhatch &raquo;</TD></TR><TR><TD CLASS="quote">the answer to your problem is ( My cousins car had the same problem) Your throttle cable is toooooooo tight. Thats why when you accelerate it stays at whatever rpm you left it at. And if you put your foot under the accelerator pedal and pull up it will bring the rpms down again.
keep your 5 bux.</TD></TR></TABLE>
VTECwalka
Nov 29, 2012 06:05 AM
psyonicdeath
Jul 1, 2005 07:25 PM
1quickcrx
Jan 21, 2005 09:27 AM
psilo
Sep 29, 2004 12:20 PM
stockegsix
Jul 28, 2004 05:33 PM
