Best Bang for the Buck All-Motor Setup!?
* B A N N E D *
ight so i run a turbo'd B18b1 rite now and the car is off the road for the winter now so i want a new set up. i waan go all moter. i'm way into down hill and the sunday morning drive. so i wana here for you guys what you think is the best bang for the buck sut up. i'm talkin bout LS or B20/vtec, poor mans R, workin a 1st gen B16. Rin out a B18c1. anything! i want strat CLEAN! any info will help. i wana start buyin parts and i wana be tuned buy this spring. thx for helpin me out
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by SkoundrelUSA »</TD></TR><TR><TD CLASS="quote">SOHC non-vtec 8valve
I felt some of the sperm in my ********* die from reading this.
Little popping feelings like eating flat pop rox and screams of why god why?!?!
b20 block, fresh bearings/seals RS cast type R pistons ARP head bolts/rod bolts
vtec head of choice with a set of skunk2 pro valvetrain and pro 1 cams
IM I/H/E of your choice
or even cheaper an all OEM ls/vtec b18b fresh bearings/gaskets b16 pistons, vtec head, type R cams/springs type R IM and bolt ons
all motor is expensive to gain power
i think what you should really do is give a budget that you are prepared to spend. will give people an idea of what you can do then
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by D-Rob »</TD></TR><TR><TD CLASS="quote">Thread title needs changed.
It is an oxymoron.</TD></TR></TABLE>
LOL.
LOL.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by mixxxwell »</TD></TR><TR><TD CLASS="quote">H
I thikn you were serious but I hope you werent. The H is a frickin pig of a motor, and this guy does his downhill running. Not a motor of choice for turns
My advice, I would take jcushing's advice. I would love to build a motor like that, I togue every single weekend.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by B.Rabbit »</TD></TR><TR><TD CLASS="quote">if there was a best bang for the buck setup that was reliable, i think we would all have it . But we dont.</TD></TR></TABLE>
thats because everyone builds a dyno queen.
</TD></TR></TABLE>I thikn you were serious but I hope you werent. The H is a frickin pig of a motor, and this guy does his downhill running. Not a motor of choice for turns
* B A N N E D *
ight so if i was gona do a B20/vtec wouldn't i want a GSR head. cus it dose have a higher comp than a B16. but the B16 is a lil cheaper. but way prob like $100 no biggy.
with B20 blocks, do i need to sleev it before i can put forged pistons in it? cus with an H i know you have to. and what would be the best crank & rod combo to go with if i did use a B20 block?
and yes i would be replasing all the gaskets and barings and what not.
i'll check on thisafter work, thx
https://honda-tech.com/zerothread/1676914
https://honda-tech.com/zerothread/1555476
these 2 are pretty much all you need to know
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by spooledhonda »</TD></TR><TR><TD CLASS="quote">wow a real coment not cus some loser. thx, keep um coming. i wana know. i wana start building</TD></TR></TABLE>
if you have to ask such a question, what makes you think any of our true answers will even be understood by you?
bang for buck = use your ls bottom end, get some p30 pistons and a vtec head with some blox B cams (350 bucks), a used itr header with a 2.5'' collector and youll make 175ish whp.
my question is, if you have a booted LS, why do you want to downgrade by about 60 whp?
why dont you tell the truth which is that your LS either isnt boosted, is blown up, or youre rocking a d15b7.
edit: laughing at "holla when u hit da vtech b!!"
