Fixing a Radiator?
Old Dec 20, 2006 | 08:11 AM
user 931176363637's Avatar
Default Fixing a Radiator?
So I was driving and I noticed smoke/steam coming from the hood. And there was a little hole in it, like 3 little holes with antifreze coming out. Im very mad about this, and it will cost $500 for a new part.... Does anyone know what to do, or if I can fix this or will i just have to get a new one.? thanks.
Old Dec 20, 2006 | 08:58 AM
JimBlake's Avatar
Default Re: Fixing a Radiator? (93Accord117)
When radiators were brass, you could solder them. But even then, the corrosion was ready to eat thru 50 other places as soon as you fixed it. I'll say trying to patch it is temporary at best.
OTOH, you should be able to find a radiator for way less than $500...
manhonda.com
hondaautomotiveparts.com
etc...
Old Dec 20, 2006 | 11:24 AM
technine's Avatar
I got my radiator at Autozone not to long ago for $100. Very easy to put in too. Take off the two top mounting brackets and disconnect all hoses (2 for 5 speed, 4 for auto) and disconnect the fans and pull up and out.
Old Dec 20, 2006 | 11:31 AM
j-spec_cc2's Avatar
if there is a small hole in the metal part of the radiator, as a very temporary fix, you could crack an egg into the radiator (while the car is running w/ the radiator cap off). other than that, like the above poster said, you can get one at any auto parts store for <u>WELL</u> under $150 for that model accord.
Old Dec 20, 2006 | 12:13 PM
raceACCORDingly's Avatar
i patched a radiator with radiator putty (epoxy) and it was supposed to be a temp fix on my friends car but it hasnt leaked again in over a year so we just left it alone.
i also replaced a radiator on my gf's civic late one night and the only thing open was the 24 hr Autozone. got one there for like a 100 bucks and works fine.
Old Dec 20, 2006 | 05:40 PM
Megaseth's Avatar
i think the question you need to ask next is why was it leaking. old age or something else. if the car is running too hot, you can bust the seams....did this in my old 240 with the stock metal/plastic radiator. not enough cooling and it ran a little too hot and the expansion split the seam and i just got a full metal replacement.
1996hondaaccord
Aug 11, 2008 03:11 PM
tkHBseries
Feb 19, 2005 06:48 PM
Krayzielix
Sep 23, 2004 10:50 AM
BluLuder
Jul 29, 2002 11:29 AM
