TRANSMISSION GRINDING IN 3RD GEAR?
Old Dec 20, 2006 | 01:09 AM
Quickridez_3's Avatar
Default TRANSMISSION GRINDING IN 3RD GEAR?
idk what is causing my car transmission to grind it only does it when you go into third gear ONLY at high RPMS it doesnt do it when you shift it at low rpms what is tha cause of this and the fix. Im sure im pushing the clutch all the way in i even tryed doing it slow and making sure it was fully engaged and even when i take it high and hold the clutch even without releasing the clutch it still grinds one person told me it could be my tranny going out and another said it can be my clutch....DOES ANYONE HAVE AN ANSWER OR A GUESS ON WHAT IT COULD BE ?
Old Dec 20, 2006 | 03:21 AM
tartje's Avatar
Default Re: TRANSMISSION GRINDING IN 3RD GEAR? (Miss Type R Tia)
sounds like a synchro
try double de-clutching going into third and see if the crunch goes away. if it does you've got your answer
Old Dec 20, 2006 | 04:26 AM
Doostur's Avatar
Flush out the tranny first... look to any large chippings.... if that dosn't fix it, your looking at a synchro problem. Bring it to acura and expect to pay 1200+
Old Dec 20, 2006 | 04:37 AM
Jon D's Avatar
Default Re: TRANSMISSION GRINDING IN 3RD GEAR? (Quickridez_3)
3rd gear synchro grinding is famous in our transmission. At this point, your best option before having the synchros replaced, which IS NOT going to cost you $1200+ is purchase some GM Syncromesh with friction modifier. That has helped many of us.
Note: synchros grinding will not prevent you from driving the car, and you may find that with less abrasive shifting you may not grind that gear at all.
Old Dec 20, 2006 | 04:57 AM
Doostur's Avatar
My friends synchro was actually shot... when he took it to acura he got railed for around 1400 bucks....
Old Dec 20, 2006 | 06:15 AM
Jon D's Avatar
Default Re: (Doostur)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Doostur &raquo;</TD></TR><TR><TD CLASS="quote">My friends synchro was actually shot... when he took it to acura he got railed for around 1400 bucks....</TD></TR></TABLE>
I hope he bought a brand new tranny with that money, bc he could have!
Old Dec 20, 2006 | 06:24 AM
walker111's Avatar
Default Re: (Jon D)
Wow, this is easily all over HT. JonD is right, its just your synchros, try some GM Synchromesh. You can get all new synchros from gearspeed.com for around 250 bucks.
Old Dec 20, 2006 | 06:48 AM
TPB's Avatar
TPB
Default Re: (walker111)
It's the 3rd gear synchro - GM synchromesh will not fix anything. It is a band-aid solution at best. If you don't want this recurring, you'll need to replace the synchro.
Old Dec 20, 2006 | 07:06 AM
Doostur's Avatar
Default Re: (Jon D)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Jon D &raquo;</TD></TR><TR><TD CLASS="quote">
I hope he bought a brand new tranny with that money, bc he could have! </TD></TR></TABLE>
Acura Dealership + Labor = $$$$
Old Dec 20, 2006 | 08:08 AM
walker111's Avatar
Acura Dealership + Labor = $$$$</TD></TR></TABLE>
= jackass for not just buying a brand new transmission for the same price!
Old Dec 20, 2006 | 08:09 AM
Dave_B's Avatar
It's a Honda, they all have that 3rd gear grind. Haven't you seen the video of the guy who makes like he's driving the supra, then makes likes he's driving a civic with No2? Even he knows about the 3rd gear gring...
But really, flush first. Then try the syncromesh. If that isn't it, get the sync's done.
Old Dec 20, 2006 | 10:53 AM
No One thinks its clutch or something minor?
Old Dec 20, 2006 | 10:54 AM
walker111's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Quickridez_3 &raquo;</TD></TR><TR><TD CLASS="quote">No One thinks its clutch or something minor? </TD></TR></TABLE>
Everyone knows its the third gear synchro!
Old Dec 20, 2006 | 11:15 AM
B-money's Avatar
Default Re: TRANSMISSION GRINDING IN 3RD GEAR? (walker111)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by walker111 &raquo;</TD></TR><TR><TD CLASS="quote">
Everyone knows its the third gear synchro!</TD></TR></TABLE>
Yup, your synchros is the issue at hand I believe. Use Gm synchro mesh friction modified. There is the normal gm synchro mesh and friction modified, which is the one that you want. I used it and it does not grind as much as before, but it helped out a lot. Before I was getting grinds at 6-7k rpms and now it grinds around 8k and above.
Old Dec 20, 2006 | 11:23 AM
tartje's Avatar
Default Re: TRANSMISSION GRINDING IN 3RD GEAR? (B-money)
putting in new fluids, which i'm guessing what you're talking about(?) will only cover up the problem a bit
pull the box apart and replace the parts, which is what i would do as i wouldnt want to damage anything else and have to pay more £££'s as a result of being lazy and putting it off
*edit* and double declutch going into 3rd and help reduce any more wear
Old Dec 20, 2006 | 11:27 AM
walker111's Avatar
Default Re: TRANSMISSION GRINDING IN 3RD GEAR? (tartje)
The GM part number for what you want is 12377916
EG6-DC2's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by tartje &raquo;</TD></TR><TR><TD CLASS="quote"> more £££'s </TD></TR></TABLE>
Does your keyboard have those symbols where our $$$ is above the #4 key?
Old Dec 20, 2006 | 11:30 AM
walker111's Avatar
Default Re: TRANSMISSION GRINDING IN 3RD GEAR? (EG6-DC2)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by EG6-DC2 &raquo;</TD></TR><TR><TD CLASS="quote">
Does your keyboard have those symbols where our $$$ is above the #4 key?</TD></TR></TABLE>
You win the most random question of the day award!@!
Old Dec 20, 2006 | 11:35 AM
tartje's Avatar
my £££ signs are above the 3 key, i also have $$$ signs above the 4 key
Old Dec 20, 2006 | 11:36 AM
walker111's Avatar
We have the pound sign above our three key also
EG6-DC2's Avatar
You win the most random question of the day award!@! </TD></TR></TABLE>
I know! I saw where he meant to say $$$ and was curious if his keyboard is different. I figured I probably wouldn't get another chance to ask it and I was curious, so I just went ahead and asked.
Old Dec 20, 2006 | 11:38 AM
EG6-DC2's Avatar
my £££ signs are above the 3 key, i also have $$$ signs above the 4 key </TD></TR></TABLE>
Thats weird....I can see the next big thing.....
"My computer is so UKDM, I customized it with the keyboard! I also have a JDM, EDM, SDM, GDM, etc.... keyboards in my collection!"
Old Dec 20, 2006 | 11:40 AM
tartje's Avatar
"My computer is so UKDM, I customized it with the keyboard! I also have a JDM, EDM, SDM, GDM, etc.... keyboards in my collection!" </TD></TR></TABLE>
lmao
Old Dec 20, 2006 | 11:48 AM
iperez's Avatar
So does anyone know where one might order a some Synchromesh Friction Modified ?? My local GM dealer has been out forever.
Old Dec 20, 2006 | 11:59 AM
EG6-DC2's Avatar
Default Re: (iperez)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by iperez &raquo;</TD></TR><TR><TD CLASS="quote">So does anyone know where one might order a some Synchromesh Friction Modified ?? My local GM dealer has been out forever.</TD></TR></TABLE>
http://www.hardtopguy.com
