K-Teller 3" Integra Catback and HKS 75mm N1 Muffler
Old Dec 19, 2006 | 08:36 PM
MatrixGSR's Avatar
Default K-Teller 3" Integra Catback and HKS 75mm N1 Muffler
Listed here is a K-Teller 3" mild full cat-back exhaust kit for a 94-01 Acura Integra. This kit WAS used on a 4 door but will also work on a 3 door as well. If you want it for the 3 door, please specify so I can cut the flanges off.
The piping has multiple coats of high-temp enamel so it will not rust. The muffler IS stainless steel but because I used regular steel the rust adhered to the surface of the muffler as well. Keep in mind that this is JUST surface rust. I did polish most of it off but you will need to finish wet sanding with WD-40 to get the rest off.
I would like to get $325 or best offer for everything. Will come with some gaskets as well. You can use any standard 1/2 inch bolts. I'd recommend some stainless hardware to make it easy to take off and install. You may also come pick it up if you would like. I do have a box to ship it in when it sells. My email address is kevinkoch@gmail.com. I check it regularly.
I MIGHT separate out the piping kit or muffler. I want $140 for the piping...
Modified by MatrixGSR at 8:53 AM 3/23/2007
Old Dec 21, 2006 | 11:19 PM
MatrixGSR's Avatar
Default Re: K-Teller 3" Integra Catback and HKS 75mm N1 Muffler (MatrixGSR)
bump
Old Dec 23, 2006 | 07:26 AM
MatrixGSR's Avatar
morning bump
Old Dec 23, 2006 | 04:05 PM
MatrixGSR's Avatar
up
Old Dec 24, 2006 | 04:35 PM
MatrixGSR's Avatar
xmas bump!
Old Dec 27, 2006 | 10:40 PM
MatrixGSR's Avatar
up
Old Dec 31, 2006 | 11:21 PM
MatrixGSR's Avatar
up
Old Jan 1, 2007 | 02:42 AM
Thurman Merman's Avatar
Lemme get that HKS muffler and ill send you my magnaflow to sell with your piping
Old Jan 1, 2007 | 04:19 PM
MatrixGSR's Avatar
Default Re: K-Teller 3" Integra Catback and HKS 75mm N1 Muffler (Thurman Merman)
you'd really ahve to make it worth my while for me to do that...
Old Mar 23, 2007 | 07:45 PM
MatrixGSR's Avatar
It is still available... I'm offering $325 for everything. If you're interested in JUST the piping I'll also just take $140 for that. No lower than these prices they're already low to start with. Don't really need to sell the muffler, if I don't sell it, chances are it will go on my EG.
MarioDb8
Apr 14, 2012 08:18 PM
strsi
Jun 10, 2008 11:41 AM
bch5428
May 11, 2006 12:06 PM
90acintegra
Jan 30, 2005 03:27 PM
2K_TEG
Feb 10, 2003 04:10 PM
