suspension is tweaked.. need help!
Old Dec 19, 2006 | 08:19 PM
pdotjones's Avatar
Default suspension is tweaked.. need help!
need help! not sure if this should be in the suspension section... my car (98 teg) hit a curb and now the wheel sits far enough back to rub against the body of the car. has this happened to anyone, or can anyone guide me in the right direction to fixing it? thanks in advance...
Old Dec 19, 2006 | 08:29 PM
95 integra's Avatar
Default Re: suspension is tweaked.. need help! (pdotjones)
thats not tweaked....thats bent. Check the suspension arms, somethings bent/broken and you hope that the chassis isnt ripped. Basically look and see whats "tweaked" and replace it.
Old Dec 19, 2006 | 08:30 PM
1world-Dc2's Avatar
u have camber issue. u probably messed up your upper control arm. need to get a new one
Fat Chick Magnet's Avatar
probobly lower control arm/ alignment.
Old Dec 19, 2006 | 08:48 PM
95 integra's Avatar
Default Re: (dc2rtek)
I'm thinking that if its so far out that the wheel is rubbing the body, its a little further then the camber/caster adjustment has play for. I mean, I've moved mine all around and I can assure you even on the far ends of the adjustment its not rubbing.
Old Dec 19, 2006 | 09:04 PM
pdotjones's Avatar
Default Re: (95 integra)
thanks for the info... i'll check tommorow and what i can find...
Old Dec 19, 2006 | 10:02 PM
Sumslapper's Avatar
Year 3030
Default Re: (pdotjones)
bought my si with the wheel pushed back. it was the lower control arm that was bent. get under the car and look for any tweaked looking parts
VegasInvasion
Dec 3, 2009 04:15 PM
theEGkid
Feb 25, 2006 05:13 PM
litterbox
11
May 16, 2004 09:19 PM
RockDawg_GSR
Nov 30, 2002 05:28 PM
lePetitePrince
Nov 1, 2001 08:05 PM
