Manual Tranny Lube
Old Dec 19, 2006 | 08:05 PM
shmack2004's Avatar
Default Manual Tranny Lube
what would be the best lube to use in my tranny? its a 91 accord dx.
i had 85w 90 gear oil it it and it grinded shifting into 2nd when it was cold and now im using 10w 30 engine oil and it grinds shifting into 3rd gear every time.
Old Dec 19, 2006 | 09:56 PM
Jmumblez2001's Avatar
Default Re: Manual Tranny Lube (shmack2004)
go to honda and get OEM lube and call it a day, unless your doing some hardcore racing then buddy you're on your own.
Old Dec 19, 2006 | 10:40 PM
iam7head's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by shmack2004 &raquo;</TD></TR><TR><TD CLASS="quote">what would be the best lube to use in my tranny? its a 91 accord dx.
i had 85w 90 gear oil it it and it grinded shifting into 2nd when it was cold and now im using 10w 30 engine oil and it grinds shifting into 3rd gear every time.</TD></TR></TABLE>
you could really mess up the syncro(i think they are brass) if you put in gear/diff. oil in your tranny.
notice 75-90 mobil1 diff oil will kill a honda tranny in a week, you probably fwaked all the syncro by doing so.
well, before you trash the trans, try using GM syncromesh FM, if that doesn't helps than nothing will.
Old Dec 20, 2006 | 07:12 AM
shmack2004's Avatar
Default Re: Manual Tranny Lube (iam7head)
where can i get GM syncromesh FM
Old Dec 20, 2006 | 05:37 PM
Megaseth's Avatar
a chevy dealership might be a good start
you can probably also get it at any autoparts store.
also, 10w30 cant be good for your tranny. it doesnt come close to the kind of oil you normally use. i've heard from many people that honda oem gear oil is the best to use...as with most oem stuff for each respective brand. at least they made a billion accords for your year/engine. if...and this is worst case senario...if the tranny is trashed, a new one should be easy to find and get. however, if you have to get a new(used) one, drain the fluid and use OEM honda first at the begining to ensure no problems.
Old Dec 20, 2006 | 05:52 PM
JimBlake's Avatar
Default Re: (Megaseth)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Megaseth &raquo;</TD></TR><TR><TD CLASS="quote">... also, 10w30 cant be good for your tranny. it doesnt come close to the kind of oil you normally use...</TD></TR></TABLE>
Honda MTL didn't exist yet in '91, so 10w-30 engine oil is exactly what the owner's manual calls for.
When Honda began selling MTL they made it compatible with their older trannys. So Honda MTL is pretty much the same viscosity at 10w-30 engine oil.
Old Dec 20, 2006 | 06:05 PM
Megaseth's Avatar
that seems so light for a gear oil, but hey, if its what they use i guess it works.
Old Dec 20, 2006 | 06:19 PM
BlUAc's Avatar
yes isnt honda mtf just a blend of 5 and 10 weight?
Old Dec 20, 2006 | 06:56 PM
shmack2004's Avatar
Default Re: (BlUAc)
i'm gonna try some 15w 40...if that doesnt make it better then its up to 20w 50
Old Dec 21, 2006 | 03:08 PM
Blamm!!'s Avatar
Default Re: (shmack2004)
Use motor oil if you have to. Better to use Honda manual trans. fluid I use Amsoil MTF but dont use thick gear oil its a honda not a 79 dodge pickup!
Old Dec 21, 2006 | 07:33 PM
JimBlake's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Megaseth &raquo;</TD></TR><TR><TD CLASS="quote">that seems so light for a gear oil, but hey, if its what they use i guess it works.</TD></TR></TABLE>'Weight' numbers for gear oil are on a whole different scale vs. 'weight' numbers for engine oil. 75w-90 gear oil is actually about the same viscosity as 10w-30 engine oil.
Old Dec 21, 2006 | 07:36 PM
Megaseth's Avatar
Default Re: (JimBlake)
ah, thanks for clearing that up.
Old Dec 21, 2006 | 08:37 PM
shmack2004's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by JimBlake &raquo;</TD></TR><TR><TD CLASS="quote">'Weight' numbers for gear oil are on a whole different scale vs. 'weight' numbers for engine oil. 75w-90 gear oil is actually about the same viscosity as 10w-30 engine oil.
then why was that **** so think and the 10w 30 was thin as **** compared to it.
Old Dec 22, 2006 | 12:24 PM
hondadude's Avatar
Old Dec 22, 2006 | 06:48 PM
Jay84ever's Avatar
Use 30w motor oil in your trans.
Old Dec 22, 2006 | 07:57 PM
JimBlake's Avatar
Default Re: (hondadude)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by hondadude &raquo;</TD></TR><TR><TD CLASS="quote">
Well, OK I was a little off. 75w-90 gear oil has a wide enough range that it can fall within 10w-40 or 10w-50 engine oil. Still, you can see that engine oil & gear oil have completely different scales.
That's just viscosity. I didn't say they were the same thing as far as chemistry.
Old Dec 22, 2006 | 08:50 PM
shmack2004's Avatar
i drained it and put in some Lucas Transmission Fix and some 15w 40 motor oil...it grinds less but still grinds
Old Dec 22, 2006 | 11:58 PM
iam7head's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by shmack2004 &raquo;</TD></TR><TR><TD CLASS="quote">i drained it and put in some Lucas Transmission Fix and some 15w 40 motor oil...it grinds less but still grinds</TD></TR></TABLE>
then you got yourself a messed up tranny then, you can't just expect it to be cure but using magic juice. this could be why you mess up the tranny the first, but putting stuff inside that you don't even know what it could do to it.
Old Dec 23, 2006 | 06:56 PM
Seems to me shmack2004 was experimenting with gear oil, i mean not once did he ever type in his post that he would go to honda and get the oem tranny fluid.
Anyway ya live ya learn.
Old Dec 23, 2006 | 08:42 PM
shmack2004's Avatar
Default Re: (Jmumblez2001)
well now i got a new tranny and im just waiting for my old one to crap out...i'll use honda mtf in the new one
Old Dec 28, 2006 | 06:44 AM
Heat's Avatar
How hard is it to change the fluid in manual transmissions?
I have a '99 LX 5-speed with about 82,000 miles. I bought it in Oct. '98 so it's just over 8 years old.
Per the maintenance schedule for normal conditions, it says "Replace transmission fluid" at 90,000 miles or 72 months (6 years), but I wasn't sure if that was for automatic transmissions or for both automatic and manual transmissions. Anyway, after reading this thread I know I need to go ahead and either do it or pay the dealer $60 to do it (the price they quoted me).
So...
a. how hard is it to do,
b. how much fluid do I need to pick up from the dealer,
c. how much will this fluid cost at the dealer,
d. what exactly do I ask the dealer for? That is, would I just say "give me (x) quarts of manual transmission fluid" and let them figure out what grade?, and
e. or is it too much of a hassle and I should just let the dealer change it out?
For what it's worth, I do most of the basic maintenance on my car by myself including oil changes and spark plug changes. OK, I know that a trained monkey can do oil changes and spark plug changes on this car, but the point is that I do get my hands dirty on this car.
Old Dec 28, 2006 | 01:50 PM
661rex89si's Avatar
honda fluids only or gm syncromesh FTW!!!!
Old Dec 28, 2006 | 03:04 PM
raceACCORDingly's Avatar
pennzoil also makes a Snychromesh tranny oil that you can get at Autozone. same exact thing as the GM stuff but cheaper.
Old Dec 31, 2006 | 03:34 PM
The G-Man's Avatar
Default Re: (Heat)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Heat &raquo;</TD></TR><TR><TD CLASS="quote">How hard is it to change the fluid in manual transmissions?
So...
For what it's worth, I do most of the basic maintenance on my car by myself including oil changes and spark plug changes. OK, I know that a trained monkey can do oil changes and spark plug changes on this car, but the point is that I do get my hands dirty on this car.</TD></TR></TABLE>
If it is anything like the older trannys, then the drain bolt will be at the bottom of the tranny casing, and the fill bolt will be above that. Look in your owners manual for the transmission fill specs, but for my '93 it is 2 quarts, or fill until it starts coming out of the hole. The level should be full enough that when you take the fill plug out and put your finger in that the fluid should just barely be below the hole.
Go to the dealer and get 3 quarts of MTF, there is only one viscosity. However, there is a new formulation of it out there. It behaves more like the GM Syncromesh fluid. It looks like this:
The older stuff is in the same bottle, except with a red cap, and dark green label. The dealer may try to get you this, but tell them you want the new stuff. Don't get me wrong, the old stuff was good, but the new stuff is much better.
Old Dec 31, 2006 | 11:43 PM
Heat's Avatar
Default Re: (The G-Man)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by The G-Man &raquo;</TD></TR><TR><TD CLASS="quote">
Go to the dealer and get 3 quarts of MTF, there is only one viscosity. However, there is a new formulation of it out there. It behaves more like the GM Syncromesh fluid. It looks like this:...</TD></TR></TABLE>
Thanks for the information. I just checked the owner's manual and Haynes manual, the owner's manual is saying that the capacity for my car is 2.1, but you actually add 2.0 quarts. I'll pick up three and hopefully don't need the third one.
Had a question though. There are two bolts. Open the lower one to drain out the old fluid, put the bolt back in. Open the upper one, add the fluid through a funnel, and when full the fluid will start to drip out of the upper hole. OK, that's easy enough, but the owner's manual says to do this on a flat surface. Can this really be done while on a flat surface, or does it need to be on jackstands? And if it does need to be in the air, I'm assuming that both front and back need to be elevated so that the car is "flat"?
One more thing - do the two bolts need crush washers like is used on the oil pan plug?
