new cat back and now bad gas milage.
Old Dec 19, 2006 | 07:49 PM
tearlessj's Avatar
Default new cat back and now bad gas milage.
I helped my friend install a new cat back 2 days ago. He just called me to tell me that his gas millage is HORRIBLE. I was thinking it was cause he got on the gas more, but he says he hasnt. Is this common, should we try to disconnect the battery over night or something? Any help is great.
Old Dec 19, 2006 | 08:59 PM
swollen_cu's Avatar
Default Re: new cat back and now bad gas milage. (tearlessj)
check for exhaust leaks. taht can cause a rapid decrease in MPG.
Old Dec 21, 2006 | 11:41 PM
ecko_kid's Avatar
Default Re: new cat back and now bad gas milage. (swollen_cu)
im not really sure about this... but i think that because more air is coming out from the exhaust and its burn more gas... just like after i install my inake it eats up more gas... so i think thats should be common
Old Dec 22, 2006 | 04:25 PM
i shiton u's Avatar
Default Re: new cat back and now bad gas milage. (ecko_kid)
intake = > mileage (if you are driving the same)
you probably notice lower gas mileage cause your foot started getting heavy
Old Dec 26, 2006 | 08:09 PM
BrakeExpert's Avatar
Default Re: new cat back and now bad gas milage. (i shiton u)
Let me educate you.
Acura is picky about their emissions. The modern emission systems have a million sensors designed to REDUCE emissions. These sensors were very very tuned for a stock car. I have seen people with open exhaust systems loose horsepower. The motor has to be tuned. The ECU is going to see a change because of an altered exhaust flow (YES, I'm not kidding, the K-series are really this picky.) For some cheap power, add an intake and reset the ECU. By ******* with the exhaust, the bad MPG is probably from the sensors reading something that they didn't like and overcompensating or doing something wierd. I don't have any specifics, please check google and honda-tech for more information, but I'm not kidding when I say you can put the B and D series type bolt ons to a K-series and possibly loose MPG and HP. First thing, reset the ECU and start up the car. Then, check for exhaust leaks. Then check any electrical connection problems. If its still ****, get on the internet and see what could have caused it man. This is all I can tell you.
theblkrascal
Honda Civic (2001 - 2005)
18
Sep 28, 2006 12:20 PM
RealAce
Aug 20, 2006 06:55 PM
skata89
May 14, 2006 01:57 PM
LaOstha
14
Oct 11, 2005 07:43 PM
Imprezn
Apr 7, 2003 10:56 AM
