heat sheild over header?
Old Dec 19, 2006 | 06:31 PM
HondaTech101's Avatar
Default heat sheild over header?
ok apparently the previous owner of my car hit a bucket of tar spilling it all over the header and drying it. well the header had a heat sheild but now its ugly as h**l! so i decided to take it off.... this wont disturb anything? i dont plan on hitting any buckets of tar ... knock on wood. haha
Old Dec 19, 2006 | 06:47 PM
importfanatic17's Avatar
Default Re: heat sheild over header? (HondaTech101)
It'll be fine.
Old Dec 19, 2006 | 06:48 PM
Default Re: heat sheild over header? (importfanatic17)
gracias i thought so.
Old Dec 19, 2006 | 10:46 PM
iam7head's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by HondaTech101 &raquo;</TD></TR><TR><TD CLASS="quote">gracias i thought so.</TD></TR></TABLE>
if i were you i would put it back, you are rising the under hood temperture for no better reason than looking good.
if you really want to get rid of the tar, get a torch and elbow grease
Old Dec 20, 2006 | 06:09 AM
'00Accordster's Avatar
Default Re: heat sheild over header? (iam7head)
wouldnt a torch warp the shape of the heat shield?
Old Dec 20, 2006 | 06:18 AM
flight50's Avatar
Default Re: heat sheild over header? ('00Accordster)
heatshields pretty much work for an oem header. most aftermarket headers make it diffcult to install one. you could use exhaust wrap to take the place of the heatshield. its better than nothing. if you don't have any serious upgrades the little rise in temperture more than likely won't rob much anyways.
Old Dec 20, 2006 | 02:46 PM
as_fast_as_u's Avatar
header wrap
Old Dec 20, 2006 | 03:08 PM
Tech-Nics's Avatar
also you can just buy a brandnew replacement sheild. just scroll down a little bit and its on your right side (facing the monitor) of course if you have a 5th genration accord.
http://www.secureleadercom.com...block
flight50
Mar 31, 2008 09:35 AM
ericstambaugh07
May 27, 2007 06:15 PM
hype r 555
45
Jan 27, 2006 07:55 PM
4LugR
Aug 7, 2005 11:53 AM
IDB4EVR
Mar 5, 2005 05:41 PM
