Clutch cable for B18B in 91 CRX.......
Old May 12, 2002 | 04:09 PM
VTECVillain's Avatar
Default Clutch cable for B18B in 91 CRX.......
Which clutch cable do I need to use with a 92 YS1 cable tranny on a 96 B18B1 motor? The motor/tranny are in a 91 CRX DX using HASport billet mounts if that makes any difference. I tried a 91 CRX Si clutch cable but it seems to be too short. I can get the bottom end into the push arm but the threaded part is to short to meet up on the bracket where you adjust the cable.
Old May 12, 2002 | 04:22 PM
KS-R's Avatar
Default Re: Clutch cable for B18B in 91 CRX....... (Hybrid Moments)
Use a 90-93 Integra clutch cable.
Old May 12, 2002 | 04:39 PM
flat-blk-HB's Avatar
Default Re: Clutch cable for B18B in 91 CRX....... (KS-R)
I used my 89 civic DX clutch cable w/ my 92 LS and I happen to have a YS1 and it worked out just fine. I personally think it should work out fine maybe you have the cable run diff. then me? who knows? but i have a 90-93 clutch cable I will sell you if you need one that bad.
brandoncumbie@hotmail.com
classciv
Jul 4, 2008 07:22 AM
Nutnwrench
Jun 18, 2008 08:55 PM
wood 1
May 30, 2006 07:42 AM
VTECVillain
May 13, 2002 07:54 AM
VTECVillain
May 13, 2002 07:47 AM
