skunk stage 2 with current valvetrain?
Old Dec 19, 2006 | 03:33 PM
CLUNKER's Avatar
Default skunk stage 2 with current valvetrain?
alright fellas ive got an sir2 b16a. i currently have itr cams in it with portflow inner springs, stock sir2 outer springs and skunk ti retainers. i was wondering if i could continue to use the same setup with a set of skunk stage 2 cams. ive been reving it to 9000rpm on the itr cams but with the skunks id like to take it to 9500. should i be ok or will i need some outer springs aswell? also. if any of you have a better cam choice im all ears. motor is stock 10.4 bottem end. stated head mods. jg proflow header with race pipe, skunk intake manifold and str 68mm TB. car will more than likely be on a direct port dry 100 shot once i get situated on a new set of cams. thanks for hearing me out. this question might have been asked in the past but i couldnt find an exact answer.
Old Dec 20, 2006 | 11:10 AM
CLUNKER's Avatar
some help here guys?
Old Dec 20, 2006 | 11:13 AM
2k.civic.si's Avatar
Default Re: (CLUNKER)
youll need new springs...the stock outer springs wont take that lift
Old Dec 20, 2006 | 03:46 PM
CLUNKER's Avatar
thanks for the input. anyone else?
Old Dec 25, 2006 | 12:45 AM
CLUNKER's Avatar
how about bc4's?
Old Dec 25, 2006 | 04:40 PM
dude_123's Avatar
Default Re: skunk stage 2 with current valvetrain? (CLUNKER)
If u are scared of dropping valves, don't raise rpm to point where power is not being made; even with upgraded valve springs. O yeah I am planning to swap out my stock b16 cams for blox stage 2 cams and am planning to use rocket motorsports SL dual valvesprings. It has slightly more seat pressure than stock, 55lbs when installed and not 75lbs+. I plan to drive it daily so keeping at stock specs is a must.
hondadriver
Sep 11, 2006 09:55 AM
eg-ed
Aug 20, 2006 03:24 PM
FROSTDC2
12
Oct 29, 2005 04:55 PM
codeh22a4
Mar 30, 2005 04:12 AM
Im-Gay
Aug 16, 2004 06:08 PM
