Parking Brake Swap...
Just did GSR rear disc conversion on my coupe but the gsr e brake cables are too short... How come my cables off my dx rear brakes wont work??? I looked it up an its the same part number for the 94 dx as it is for the 00 si...???
Edit: I was just told by some people that it wouldnt work i didnt actually try it out, i was wondering if anyone knew the real deal with this....
Before you buy anything else just make sure you check to see if you got them mixed up. If the left is on the right and vice versa they both will seem too short. I ran into the same problem with my swap on my 2000 coupe.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by EJ8ona »</TD></TR><TR><TD CLASS="quote">Before you buy anything else just make sure you check to see if you got them mixed up. If the left is on the right and vice versa they both will seem too short. I ran into the same problem with my swap on my 2000 coupe. </TD></TR></TABLE>
im not sure if ur talking about ebrake cables or whole assembly.. Assembly, i compared them to my roomates GSR an thats how i installed them "with caliper on the back end of the assembly" so i was sure i had that right, and EBRAKE cables, i never removed or installed they came already on my assembly that i got... An yeah im 100% there off a GSR "i helped take'm off" haha... I just dont understand this damn thing.. I compared all the part numbers an all that an for all model civics 92-00 the ebrake cable was the same part number....
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by BlueIntegraBoy »</TD></TR><TR><TD CLASS="quote">You sure you got GSR cables? Integra cables worked on my hatch (same wheelbase). Del Sol cables are shorter.</TD></TR></TABLE>
I was told that I needed civic ones for my coupe but gsr would work on hatches an crx's....
CivicSiRracer69
Oct 25, 2004 08:34 PM
92b18cx
May 14, 2004 12:01 AM
